A new addition to the household for 2003.
#2 |
And the centerfold fully undressed picture for you naughty members !
#3 |
Yep, it pretty much is. Very nice job!
I have to change one of the pots in my BOSOZ so one of this days I'll post pictures and give you a chance to take shots at my version.
#4 |
In terms of "audiophile" components this is what I used:
1) Overated trafos at 2x120VA instead of 2x60VA 2)Ultra fast soft recovery diodes for rectification (IRF) 3)Aerovox and Black Gate caps for the power supply boards. 4)Sikorel 2200uF caps under the main PCB 5)Holco non-magnetic resistors 6)Dedshete damping sheets to minimise chassis ringing and decouple PCB's 7)Silver-plated hook-up wire from Audio-note. 8)DACT gold plated stepped attenuator and selector switch. Further mods may include replacing film coupling caps with Black Gate BG N non-polar as advised by Peter Qvortrup of Audio-note. Perhaps bypassing Sikorel caps with film and film+foil caps. Now to the sound of this sexy little bride of my Aleph 5's. At first I only heard it unbalanced in and out for a few days.Compared to my passive set-up which is very transparent I didn't notice any loss of transparency which is quite a feat if you think how many more connections and active parts the signal goes through. There was a much more powerful dynamic sound especially in the bass which was what I was hoping for. Of course pace and timing were also much better.However with all the extra dynamics and punch there was a subliminal residual feeling of a bit of hardness on some recordings around the midrange. I didn't know if this was because my passive set-up was softening the recordings and that the BOSOZ was showing more of the deficiencies of some recordings or that it was adding something of it's own. Then one day I wired up the balanced connection in the Alephs and switched on. Well , with the first few seconds of music my jaw dropped, I started rubbing my eyes and pinching myself in case I was dreaming because I wasn't sure I was listening to the same system , much less the same pre-amp! Well allright, maybe I am exaggerating a teeny bit but we are fanatics aren't we? Seriously I thought that my speakers had "grown" much bigger even taking into account some small level differences. Everything was there but more of it. The soundstage expanded and deepened cosiderably, there was more space between instruments and the bass got even better!And on top of it all everything sounded more natural with that residual hardness completely gone. In I am completely in love with balanced operation.Just to give you an idea I tried also balanced in from my TEAC VRDS-25 CDP and it actually sounded a bit better than my unbalanced Perpetual Technologies P3A-P1A-Monolithic PS which usually mops the floor with it. The Teac is clocked and op-amped but the P.T. combo is also op-amped with OPA627's and with soft recovery diodes and is generally regarded as close to state of the art for DAC's (as well as being almost twice as expensive as the CDP) I am annoyed now that I can't get balanced operation from it because it doesn't seem to be a dual differential circuit. |
#5 |
Hello protos,
Nice layout. I like the blue LED and your cone stands. Try to make selector and volume pot knobs out of wood, with little larger diameter, they will look even more awsome. Why you did not use filter capacitors on the main PCB ? The circuit will perform even better with them. Best regards, Kristijan Kljucaric http://web.vip.hr/pcb-design.vip |
#6 |
Hello,
Never mind for the capacitors. I just saw them under the PCB. Best regards, Kristijan Kljucaric http://web.vip.hr/pcb-design.vip |
#7 | |
Sony's cd players offer often balanced operations before their unbal op amps
#8 |
I just wanted to say that I got the same experience in regards to the BASS - if connected in balanced mode.
#9 |
#10 |
Protos!, verrry nice.
i like your use of wood for the face plate. ...the LED always has to be blue, doesn't it m. |
| To BOSOZ or not to BOSOZ... please comment. | spence | Pass Labs | 4 | 27th February 2012 02:57 AM |
| Poll! What do you use in your X-BOSOZ or BOSOZ for Volume Control and Input Selector? | promitheus | Pass Labs | 87 | 19th February 2006 03:15 PM |
| X-bosoz vs. CCS X-bosoz, how does the sound compare? | acliao | Pass Labs | 14 | 26th February 2004 12:55 AM |
| Bosoz | lawbadman | Pass Labs | 5 | 14th July 2003 02:10 AM |
| 10K Pot for the BOSOZ | raincheck | Pass Labs | 13 | 20th September 2002 06:22 PM |
| Page generated in 0.13133 seconds (81.16% PHP - 18.84% MySQL) with 11 queries |
