hi, I am using kristijans board, and I have laying arround few dact 10kohm atenuators, how ever it way too high for p 1.7. at 10kohm sound is very loud. it should be 1-2kohm I think
what parts I should change do use this 10kohm dact in p 1.7? thanks in advance
natural sound reproduction from traditional dynamic drivers?!! come on.. no no, it can be.. it must be!.. |
#2 |
You can use a 10k attenuator on the input instead.
/U. |
#3 |
are you shure you connected it the right way? The only difference between a 2k and a 10k pot is the output and input impedance. The attenuation should be the same. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#4 |
hi wuffwaff if I use on input I will need balanced atenuator(double price)
I am using in in the same place as in kristijan schematic. just instead 2kohm I use 10kohm. the sound is very loud with 10kohm even in mimimum position(10kohm)
#5 |
1K where the pot is runs fine according to NP
#6 |
If you have the DACT connected as the 2K potentiometer in your schematic you effectively do are not attenuating the signal. The 2K potentiometer sets the Master gain for one channel as per the original P1.7. You do not require a DACT for this just s simple multiturn pot. You need to move the DACT to the input or output (preferably) to reduce the volume...... Hope this helps! |
#7 |
#8 |
I found thread
Aleph P 1.7: Need help to choose som caps where Mr. Nelson said that there is possible to use 1kohm single pot to adjust volume.(place a single potentiometer between the Source pins of the Mosfets, where a good value is about 1 Kohm.) anybody tried that?
#9 |
Hi Elviukai,
I tried, and gave up.... I have the same PCB as you have, but wanted to use large capacitors meaning I had all sort of problems with space. You can use the 2K potmeter to play with the gain, but normally you also need to attentuate so that would be a no-go. I had a pot I tried to put in front, but as my CD player had no bufferstage (don't ask) that ended into very strange effects. I ended up using a 2K resistor bank on the output, using a board by Mikkel. Now I have a great sounding P1.7! Greetings, Harry. |
#10 |
Hi Harry,
Your preamp lokk very nice. Notice you have a display on front panel and relay volumn control. Is it remote control ? I like to have one like this for my BZLS. Do you mind post a link where to buy this one, how much is this ? Thanks ! John |
| How to attenuate the alt | kerrysun | Full Range | 1 | 30th October 2008 09:12 AM |
| Best option to attenuate the signal in this simple cct | HankMcSpank | Solid State | 28 | 7th August 2008 09:20 AM |
| Attenuate tweeter level by 2 db | bastek | Multi-Way | 8 | 27th May 2008 10:08 PM |
| how to attenuate a speaker as a mic? | newmz | Instruments and Amps | 2 | 14th February 2007 05:29 AM |
| Attenuate? | muhy3 | Multi-Way | 3 | 24th October 2004 01:53 AM |
| Page generated in 0.10961 seconds (80.24% PHP - 19.76% MySQL) with 11 queries |
