Obviously the more the better for bias, but as a general rule, what is the minimum BIAS I should consider in a ClassA circuit?
For my Zen, I know that the bias was set to about 3x the peak output current expected (10-watts into 8 ohms ~ 1.25 amps, BIAS set to 3amps). I just got some HD 555s for Christmas and I'm working out a design for a headphone amp. Given my max output current is more in the 100mA range, I can afford quite a bit more relative bias than in the Zen. I normally use the "10 is significantly larger than 1" rule in most of my designs so my first instinct is to set my bias to 10x my output current. What do you think? -- Danny |
#2 |
Actually, 10W into 8 Ohms represents something closer to 1.1Arms. The extra bias is of use for those whose speakers are less than 8 Ohms...which includes nearly everyone since most speakers have impedance dips.
For headphones I'd say you could do quite nicely with an amp of bias. I just described a headphone amp with .5A bias in another thread, albeit with 24V rails. How high you set your rail voltage will factor into your design, too. I chose 24V because MOSFET capacitances increase rather rapidly below that. If I'd gone with bipolars, I could have used lower rail voltages. On the other hand, it would take more current to drive the circuit. Just a question of which choices you want to make. Grey |
#3 |
I beleive the real reason for the 2-3Amps of bias is due to the MOSFETs themselves. They start to get pretty linear above 2 Amps or so. However, in a balanced, differential or bridged circuit, the two sides of the amp tend to cancel each others non-linearities
#4 |
Rule of thumb. Put you thumb on the heatsink for more than 5 seconds and the bias is to low.
MikeW |
#5 | |
The one and only
| Is there a rule of thumb for calculating the transormer's VA rating? | Bricolo | Solid State | 16 | 23rd June 2006 12:22 PM |
| Rule of Thumb on 3 way driver SPL's. | 2litre | Multi-Way | 4 | 15th September 2005 08:21 AM |
| Thumb Rule for determining Approx output power of class AB amp | rajeev luthra | Solid State | 12 | 3rd August 2004 07:34 PM |
| No. of parallel BJT? Rule of thumb? | sam9 | Solid State | 4 | 26th April 2004 10:48 PM |
| Page generated in 0.07935 seconds (77.57% PHP - 22.43% MySQL) with 10 queries |
