Old 30th January 2007, 04:34 PM   #1
Has is offline Has  Croatia
Default Aleph5 trouble
Few days ago i measured Amp currents an voltages and i make short connection betwen Drain of one dif trans and 221 Ohm (Kristijan's R16). Now one channel is quiter than other. When i put sin ton one channel is400mV(normal) and other 200mV(bad). I try to change input pair tranz but the problem stay, thing that problem is't here. All 1Ohm resistors have across them 0.6V. On Q3 is 3.8V at drain, at R14 is 4.75V. It look like only 3 tranz is working. Output voltage is half from channel which is correct. Offset is cca 80mV. Is someone have some idea what could be wrong? All other marks for tranz and rasistors is from pass service
thx
Old 30th January 2007, 06:08 PM   #2
wuffwaff's Avatar
do you still have the connection between -in and ground in both channels? This would change the gain by 6dB.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 30th January 2007, 07:00 PM   #3
no i have xlr connection so - and ground isn't connect.
Pot for my Aleph5 Llafriel Pass Labs 2 29th August 2005 10:15 PM
Another Aleph5 mefinnis Pass Labs 57 2nd June 2005 01:10 PM
C7 cap on Aleph5 Duck-Twacy Pass Labs 9 14th September 2004 03:11 PM
Yep, another Aleph5 rwagter Pass Labs 19 31st May 2003 08:06 PM
HELP .... Aleph5 mefinnis Pass Labs 17 10th March 2003 05:32 AM
Page generated in 0.06229 seconds (81.30% PHP - 18.70% MySQL) with 10 queries
