Advice Please on best pass diy amps for 3 way horns.
Old 30th January 2007, 12:36 AM   #1
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Default Advice Please on best pass diy amps for 3 way horns.
I use a pair of UK produced IMPULSE H2 (late type) horn speakers. The bass is a rear loaded horn, whilst the midrange is front loaded...the tweeter is an earlier focal unit and not loaded. These speakers though now vintage are very uncoloured, musical and very very fast. They also image well.
I wish to build a Pass amp and preamp to drive these - the nominal load is 8 ohms and the sensitivity is good at around 94-6 Db. My primary source is a turntable using a very low output original Kondo Audionote MC cartridge.
I think that an amp in the 20 to 30 watt per channel range will give all I need by way of power.
I would like a project which is not too testing to build and for which test facilities greater than a good Fluke 85 multimeter are not needed. I have trolled through many SS threads and seem to have many choices...As it is probable that anyone who reads this will have far more exposure to Mr. Pass's designs I will be grateful to have their views.
Many thanks,
Brianco.
Old 31st January 2007, 12:30 AM   #2
GRollins is offline GRollins  United States
Sounds like a job for the Aleph 3. A later iteration was known as the A30. Either one gives 30W of class A, and does not require a lot of fancy setup stuff to get working. A little matching of devices is required, but that can be done with a meter. The bias is set by component choice, not by diddling a pot, so the bias is preset.
Grey
Old 1st February 2007, 04:26 PM   #3
brianco's Avatar
Grey
It was kind of you to reply.
I will go with this as it seems simple enough for my purpose and lack of skills! Is anyone still selling boards for the A30?
I am at present building a mc pre and line amp which uses a pair of J147 at the front and a sk214 at the linestage. It is completed with a transformer output. The design was given to me some years ago by Be Yamamura, along with Tamura transformers and beautiful 600ohm h pattern pots. So provided my input is not at fault it should sound good!.
Thanks again,
Brian
Old 1st February 2007, 04:33 PM   #4
Boards are probably available somewhere, but I don't know the details. I'm afraid I don't keep up with such things. Perhaps someone will post along those lines.
Grey
Old 1st February 2007, 04:39 PM   #5
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Brian,
you must be a very lucky person:
http://www.diyaudio.com/forums/showt...98#post1085298
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 1st February 2007, 05:12 PM   #6
brianco's Avatar
Thank you both Grey and Jacco.
I have already sent a mail to enquire!!
Will come back when I have something running!
Brian
Advice Please on best pass diy amps for 3 way horns.Hide this!Advertise here!
speakers, horns, tubes, amps and cans for sale! xcortes Swap Meet 8 31st July 2008 09:40 PM
WTB: GC for Horns 109db 300hz up , some advice please hum4god Chip Amps 0 12th August 2007 08:23 PM
Op amps and back loaded horns MikeFarad Full Range 1 1st January 2007 05:50 AM
Amperes of Pass amps & Pass for ESL rick57 Pass Labs 3 4th August 2005 04:28 PM
two value tube amps for active DIY horns rick57 Tubes / Valves 19 15th April 2005 10:15 PM
Copyright ©1999-2017 diyAudio
