Old 28th January 2007, 10:12 PM   #1
MikeW is offline MikeW  United States
MikeW's Avatar
Default Frequency response vs. output power
How much does the frequency response change for one watt output to full rated output power on a Pass labs amp? All the reviews I read are for small signal frequency response. Is there a difference. Does anyone have some data?
MikeW
Old 28th January 2007, 10:58 PM   #2
Mike,
Bode is the keyword you're searching for. As in Bode plot. Yes, the bandwidth shrinks as the power (interpret this as gain) increases.
Chip opamps have really stupid open loop bandwidths...like 100Hz. It's only after you apply gonzo amounts of feedback that the bandwidth becomes tolerable.
If you meditate on all the ramifications and implications of this junk you're likely to end up like me--meaning someone who thinks that 250kHz to 300kHz open loop bandwidth is a good start. I say that having just come up from the Dungeon wherein my Evil Experiments managed a whole, astounding 10kHz. Unsatisfactory. Need to stop and think things over. Bummer.
Grey
P.S.: Good talking to you. There's no one to talk audio with out here in the hinterlands.
Old 28th January 2007, 11:16 PM   #3
flg is offline flg  United States
flg's Avatar
Grey, Southern R.I. isn't any better. But, MikeW, your only a stone's throw away...
Old 29th January 2007, 01:26 AM   #4
Formerly "jh6you". R.I.P.
Babowana's Avatar
Somewhat difficult for me to understand.
I am simplified. Nevertheless, as the rolloff is hapenning
depending purely on the RC network, I understand that the
rolloff point is independant of the power level.
I.e. the bandwidth of an amp is the same at any power level.
The distortion might be increased at the power increase, though.
Where I'm wrong . . . ?
Old 29th January 2007, 02:17 AM   #5
jackinnj's Avatar
the hinterlands aren't in SC -- at least you guys know what a "grit" is.
Old 29th January 2007, 06:18 PM   #6
The one and only
Nelson Pass's Avatar
Default Re: Frequency response vs. output power
It's pretty much the same.
Old 29th January 2007, 06:24 PM   #7
The one and only
A little later:
Since there was an XA100.5 on the bench being tested for
frequency response, I checked it at 2W, 50W and 100W.
It was 2 dB down at 100 KHz at 2W, 2 db at 50W, and 2.2 dB
at 100W.
Old 29th January 2007, 11:28 PM   #8
gl is offline gl  United States
So Nelson,
I don't recall having heard of an XA100.5 previously. What is the difference between it and the the XA100? Thanks.
Graeme
Old 30th January 2007, 12:49 AM   #9
Babowana's Avatar
at 100W.
I guess the last value, 2.2dB, must be due to
the accuracy tolerance of your farsighted glasses
Old 30th January 2007, 04:31 PM   #10
MikeW's Avatar
A little later:
at 100W.
MikeW
Understanding Zaph's Frequency Response and Power Handling Curves jarsoffart Multi-Way 5 24th March 2009 08:29 PM
Output transformers and frequency response dsavitsk Tubes / Valves 21 3rd December 2006 06:48 PM
frequency response pmarcouxx Digital Source 2 20th July 2005 07:43 PM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
Page generated in 0.12907 seconds (72.41% PHP - 27.59% MySQL) with 10 queries
