#11 | |
The one and only
Compare to its predecessor it has a wider, more lush midrange, and better clarity and detail.
#12 |
Thank you. I will look forward to it's release.
Graeme |
#13 | |
Unfortunately, this is one of those 'ain't no free lunch" things. Yes, the RC network (I'm assuming that you're referring to the feedback loop) rolls off the frequency response, but even in a circuit with no feedback at all, the frequency response will decrease at higher gain levels. Plays havoc on my intentions to build wide bandwidth circuits. Grey |
#14 | |
Mike, There is a concept in amplifiers called "Gain-Bandwidth product". Basically an amplifier typically has a constant value for the closed loop gain * bandwidth of the amplifier. In other words, for a given amplifier, your bandwidth changes porportionally to the gain you set (typically through NFB). In a normal amplifier, your gain will be fixed regardless of the input signal (and therefore the output signal). So, the bandwidth, which is essentially your frequency response, should not change regardless of output power because the output power was adjusted simply by injecting a stronger input. NPs response should validate this statement. Typically NFB is used to adjust the closed loop gain (and therefore expand the bandwidth). Although emitter/source degeneration is typically not considered feedback, it does affect this as well. This is why, as a previous poster said, many opamps have open loop bandwidths of only 100Hz but when feedback is applied (ie, the closed loop gain is reduced), the bandwidth is extended. Now, if you instead adjusted the output power by adjusting the through the feedback/degeneration or Rc/Rd's then you woudl be adjusting the bandwidth as well. -- Danny |
#15 | |
Formerly "jh6you". R.I.P.
I was referring to the original question. I still believe that the different output power levels change neither R nor C values, which are forming internal RC networks and their critical frequency points. |
| Understanding Zaph's Frequency Response and Power Handling Curves | jarsoffart | Multi-Way | 5 | 24th March 2009 08:29 PM |
| Output transformers and frequency response | dsavitsk | Tubes / Valves | 21 | 3rd December 2006 06:48 PM |
| frequency response | pmarcouxx | Digital Source | 2 | 20th July 2005 07:43 PM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
