Old 4th January 2003, 02:43 PM   #1
PsykoK is offline PsykoK  France
Send a message via ICQ to PsykoK Send a message via AIM to PsykoK
Angry [HELP!] PS problem
Yesterday I built 2 Pi filters for my Zen V4 and today I run some tests to verify it.
The 2 filters are the same and use the same part list.
Is use the following parts for each filter
- 8 x 10000uF from BC ref: 051
- 1 x 4,7nF from WIMA ref: MKP10
- 1 x 2.2mH
To build these filters I use a PCB from my conception:
Something is going wrong with one of these 2 filters because I don’t get the same result with the 2.
For a better comprehension a call the first filter F1 and the second F2
On first I test the 2 filters with a transformer (350VA, 18-0-18) and a diode bridge (600v,25A)
All voltage on the bride and on the transformer are ok!
I check the output voltage with my MM a get around 53V with the 2 filters but when I use my scop, I get an full flat output sig for F1 and something like capa sig with a load/unload for F2. But the DC offset is still the same: 53V on the scop for F1 and F2.
When I check the voltage one the filter without any AC source, I get around 53v for F1 and 2V for F2. The voltage on F2 is decreasing but not for F1.
Can someone tell what is going wrong and why?
Old 4th January 2003, 02:59 PM   #2
eLarson is offline eLarson  United States
eLarson's Avatar
Are any of the caps (even C9) getting noticeably
warmer than the others in F2? (A bad part?)
When you say "any AC source" do you mean the
transformer, or a signal driving the circuit being
powered?
Do you have a picture of the waveform you are seeing
with F2? I'm having a hard time picturing it.
Erik
Old 4th January 2003, 03:12 PM   #3
Default Solution
chame on me!!!
I found the problem, I mount a cap in the wrong wy on the board
eLarson , thanks for your help
Old 4th January 2003, 05:00 PM   #4
eLarson's Avatar
No problem at all. Glad to be of service.
Erik
mtx amp problem [[help!!]] fuzzypinkhat45 Car Audio 3 8th July 2008 05:34 AM
CDM 2/29 Problem – HELP! Bassivus Digital Source 29 23rd December 2007 10:00 AM
FRD/ZMA Problem Twisted85 Multi-Way 5 4th December 2006 01:19 PM
p3a problem MaXiZ Solid State 17 16th July 2005 07:14 AM
Page generated in 0.08299 seconds (69.95% PHP - 30.05% MySQL) with 10 queries
