Modifying the Bride of Zen.
Old 15th February 2001, 04:27 PM   #1
pixie is offline pixie
I'm not going to buy a new transformer for my Bride of Zen.
I have a 30V Transformer laying around.
So, 30V * sqrt(2) is 42V after the Bridge.
If I stack 4 10V zeners instead of 6 is that all I need to do? It looks that way to me.
I should get a clean 40V out of it.
Can anyone see any other parts that will need to change? Possibly increase the power rating on the pull up resistor? I wouldn't think so.
Thanks,
pixie
Old 15th February 2001, 05:01 PM   #2
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Modifying the Bride of Zen. Send a message via Yahoo to vdi_nenna
Cool Bride of Zen Trans
The project calls for 30+30 trans at.5 amps.
The Avel equivalent is the D4007, which is a 30v-0-30v @ 0.5 amps.
The trans is connected in series.
The power supply is suppose to produce 86v and is regulated to 60v by the zeners.
If you have a 30 + 30 with more current capability, that's even better. I originally had a 6 amp 30+30 trans. in my BOZ and it sounded so awesome. I have what the article calls for now and it's not as warm and detailed as it was with the larger trans. I'm poppin' that puppy back in when I get the chance.
Good Luck!!
Vince
Old 15th February 2001, 05:52 PM   #3
Default Amps.
I have amps to spare on this 15+15. It's 7.5A.
That's not the problem. The problem is, I don't want to spend another $60 on a 30+30 even at 1A.
So, given that I'm not going to get a larger transformer, what do I need to do to use mine?
Thanks,
pixie
Old 15th February 2001, 06:55 PM   #4
blmn is online now blmn  Brazil
blmn's Avatar
Pixie,
I donīt know the circuit, but it seems you need a +/- 30V dc regulated power supply using an 15+15V transformer, right?
The transformer you said you had is big, but it appears doesnīt be a big problem for you.
Considering this, you can use diode voltage doubler circuits on both sides of the transformerīs secondary winding to achieve +/- 43V or more at the input of the regulator circuit.
Itīs easy and any basic electronic handbook has the information you need to do this.
Be carefull about ripple and decoupling. Use the best filtering capacities as possible.
Old 15th February 2001, 07:31 PM   #5
vdi_nenna's Avatar
Lightbulb Supply Doubler.
Pix,
You can see how this is done in a Booklet from Radio Shack that costs about $3-$4. They have them in all their stores.
It's called Engineer's Mini-Handbook, Basic Semi-Conductor Circuits, by Forest M. Mims III. #276-5013a. There is a series of them. I have a few and come in handy from time to time.
You'll probably need a few diodes and caps, but that's about it. You may need to baypass the rectifier circuit on the board, but I'm not sure. Study the circuit and see what you need to do.
If you are in a rush, I can try to draw it up and I'll email it to you. Get back soon, because I won't be near a computer all weekend!
Late!
Vince
Old 15th February 2001, 08:00 PM   #6
Default Doubler
http://www.kwarc.org/bulletin/99-04/tech_corner.htm
This is a circuit for a full-wave voltage doubler (or so).
So, this could work. I will need a couple more diodes and caps.
Would you use this? Is the Radio Shack one different? I probably have it laying around too. I'll have to dig deep to find it though.
Later,
pixie
Old 15th February 2001, 09:48 PM   #7
vdi_nenna's Avatar
Exclamation Doubler
I don't think it's the same. You might want to dig up the RS booklet. The one in the RS book has 2 caps across the rectifier's output.
If you email me tonight, I'll draw it up and email it to you tomorrow.
Vince
vincenet3@juno.com
[Edited by vdi_nenna on 02-15-2001 at 04:53 PM]
Old 15th February 2001, 10:54 PM   #8
promitheus is offline promitheus  Europe
promitheus's Avatar
The use a voltage doubler in the A40 amp in the passlabs site. Why donīt you read that. I think it has all the info.
Old 16th February 2001, 08:52 AM   #9
Hoffmeyer is offline Hoffmeyer  Denmark
I`ve just simulated the circuit from http://www.kwarc...., and the U-output is : [U(tr)pp - (2xU(diode))], meaning if you have a transformer with 15V peak/30V pp you`ll get @28V out.
If the capacitors are 10.000uF, the diodes, with their anode to gnd, will have to handle @22Amp at start-up.
Good luck.
Hoffmeyer ;0)
Old 16th February 2001, 09:18 AM   #10
McKajVah is offline McKajVah
Default Simulation program
Hoffmeyer:
What program do you use to simulate the circuits?
-Kaj
Modifying the Bride of Zen.Hide this!Advertise here!
Bride of Zen, Bride of Son of Zen 2Bak Pass Labs 116 26th April 2018 11:47 AM
New PCB for bride of zen maartentje Pass Labs 6 28th February 2005 07:19 AM
Bride of zen PCB maartentje Pass Labs 8 14th February 2005 01:26 AM
bjt bride of zen renjiish Pass Labs 1 24th September 2004 03:54 PM
bride of son of zen at +-30v hifi Pass Labs 1 12th February 2002 06:52 PM
