Modifying the Bride of Zen.
Old 16th February 2001, 09:27 AM   #11
Hoffmeyer is offline Hoffmeyer  Denmark
I`m using Orcad`s PSpice 9.1.
It`s the best I`ve come across so far.
You can get a Lite version of ver. 9.2 from http://www.orcad.com .
Hoffmeyer ;0)
Old 16th February 2001, 04:34 PM   #12
pixie is offline pixie
I looked at the A40. It looks like it uses two Full-wave bridge rectifiers to get +-V for two channels. So, you're telling me to use the -V as ground for my Bride? Then the ground for the Bride is not equal to earth ground? I only want one channel remember. This doesn't make sense.
Thanks,
pixie
Old 27th November 2001, 03:07 AM   #13
mg16 is offline mg16
Default Pixie.. Chuck your transformer..it won't work
30 volts with the sec. in series will give you about 42 volts total. The Mosfet draws 40 ma. The drain resistor is 1000 ohms. You will lose all 40 volts across the drain resistor. You need at least 20 volts across the mosfet. If you bias down to 20 ma., that would leave you 20 volts of swing, or + - 10 volts output voltage swing. I am not even sure if 20 ma. is enough to bias the mosfet "on". I would save your transformer for another project, and buy a 30+30 at 3 amps or more transformer. That is about the only change I made to the stock version, and it sounds fantastic. Its worth building it as Pass intended, but with more current capability in the supply.
mg16
Old 27th November 2001, 03:42 AM   #14
paulb is offline paulb  Canada
Default Voltage doubler will work
There's no reason why a voltage doubler won't work. It was the A75, not the A40, that used it.
See http://www.passlabs.com/projects/a75_2_4.htm
and the following section for a description of voltage doublers.
Note the doubler is a half-wave rectifier, so you should probably double the filter cap sizes.
Modifying the Bride of Zen.Hide this!Advertise here!
Bride of Zen, Bride of Son of Zen 2Bak Pass Labs 116 26th April 2018 11:47 AM
New PCB for bride of zen maartentje Pass Labs 6 28th February 2005 07:19 AM
Bride of zen PCB maartentje Pass Labs 8 14th February 2005 01:26 AM
bjt bride of zen renjiish Pass Labs 1 24th September 2004 03:54 PM
bride of son of zen at +-30v hifi Pass Labs 1 12th February 2002 06:52 PM
