I am posting a general question and am hoping for some constructive ideas.
In the few Class-A power amps that I have built, typically an Aleph-X, the closed loop frequency response always seems to have a hump before the -6dB decay, indicating inductivity somewhere. Of course one can damp this down by increasing the value of the capacitor across the feedback resistor. But I wonder where the inductivity comes from and how it may be removed. The frequency response as shown is with a speaker as load, but it does not change much even if the speaker is removed and replace with say a 100 ohm power resistor. It also changes little even if one increases the values of the gate resistor of the output FETs. Any comments as to what the root cause of the hump might be ? Thanks, Patrick |
#3 |
So Jürgen, take Aleph-X as an example, how would you change the open loop characterisitcs to increase the phase margin ?
Patrick |
#5 |
While I take your point about phase margin, I am not sure whether I agree entirely that it has nothing to do with inductivity.
You can have too small phase margin and hence instability even without that hump. But the hump indicates excessive gain at high frequencies. In fact, if you take out the feedback cap entirely, the hump would be more prominent. My question was not how to suppress that hump. One can just increase the feedbacl cap. Rather, I wonder what causes the hump in the first place, and whether it can be removed without adding a feedback cap. Feedback cap is the easy way out. Patrick |
#6 |
The one and only
The hump means that you have a higher Q value to the rolloff
than you probably want, meaning there are at least 2 poles of rolloff operating before you reach the unity gain point at high frequencies. There is nothing technically wrong with this, but as a rule we like to remove it for sonic or at least aesthetic reasons. You can do this by lowering the frequency of one of these poles (that is to say, slow down some portion of the circuit) or by raising the frequency of one of the poles (speeding up some part of the circuit). Usually we just trim the feedback cap, and that works fine. I should add the a 500 KHz rolloff is quite fast, so you have some bandwidth to burn IMHO.
#7 |
Thank for the advice. I shall look into it further.
I have tried the feedback cap route and ended up with 300kHz -3dB. Still very fast, but I take it as a challenge to cure the hump rather than correct for it with the feedback loop. Pending further investigation. : ) Patrick |
#8 |
Hi Patrick,
the other caps to look at are in the active current sources. I remember the same thing when building my Aleph-X´s. It must be somewhere at the beginning of the thread. William
een ooievaar is geen konijn want zijn oren zijn te klein! |
#9 |
William,
It is a general problem not specific to Aleph-X. For example, my Xed Lindsley Hood MOSFET has a similar response, and it uses a phase splitter to drive the output FETs instead of the Aleph Current Multiplier. Of course the phase splitter also has its own bandwidth, phase shifts, etc. Patrick |
#10 | |
Another way to say this is that you have still a lot of gain when the phaseshift increases. Such a case means that the negative feedback tends to change to positive feedback which means increase of gain rather than decrease. As Nelson pointed out, you can decrease the phase shift, or increase the gain roll-of with frequency to get rid of it. Problem is often that these things are coupled, for instance if you increase the gain roll-off with a cap you probably at the same time increase phase shift so it doesn't get you very far. Or you can increase the closed loop gain (less feedback). Jan Didden
/Another new issue: Linear Audio Volume 3! |
| Lower closed loop gain? Higher slew rate. | fotios | Solid State | 4 | 27th July 2009 01:41 AM |
| closed end high frequency transmission lines | thadman | Multi-Way | 6 | 8th April 2009 01:59 AM |
| Doubts on Phase Response and Frequency Response | dumrum | Multi-Way | 11 | 5th April 2004 10:39 AM |
| Opamp phase shift - open and closed loop. | Circlotron | Analogue Source | 8 | 23rd April 2003 07:06 AM |
| Page generated in 0.11041 seconds (78.97% PHP - 21.03% MySQL) with 11 queries |
