Old 2nd January 2003, 10:26 PM   #1
xsnailx is offline xsnailx  Poland
xsnailx's Avatar
Send a message via AIM to xsnailx Send a message via MSN to xsnailx Send a message via Yahoo to xsnailx
Question an old boring question but... please help me
hello!
ok! after a couple of hours of thinking and reading i
want to ask what kind amplifier
will suit my speakers best?
here is my cosiderations
2 zens v 4 running in a bi amp mode
one aleph x or one aleph 3
or even 2 aleph x or 2 aleph 3 in a bi amp mode
maybe another aleph instead?
both of them will work with bride of zen preamp
or balanced line stage pre
my speakers specs:
sensitivity 1W @ 1m - 88 dB
impedance - 6 Ohm
frequency area +/- 3dB - 30 - 23 000 Hz
Crossover frequency - 3 kHz
system 2 way.- Basreflex
authentic voice model 221
www.authentic.cz
i have seen some people from poland here
so i will be pleased to know about good source of
radiators and aluminium plates in poland?
maybe some of you
(from poland) have any pcb's for sale?
Old 3rd January 2003, 11:57 AM   #2
xsnailx's Avatar
Default update
definitly it will be an aleph 3 or aleph x
if the power will be not enough. i will run them in bi-amp mode
but the second problem remains:<
so i beg anyone from poland to help me
please
ps. is aleph x much harder to bylid than aleph 3? from that what i have read they are ot as easy as zen but ... on the same level?
Old 3rd January 2003, 03:58 PM   #3
Sparhawk's Avatar
Default Re: update
I haven't built any of them yet, though I plan to build the Aleph-X with Chad's boards. From what I have read, the AX requires quite a bit of tweaking, whereas the Aleph 3 is more "plug and play".
Old 3rd January 2003, 05:50 PM   #4
xsnailx's Avatar
Default thank you for your reply
ok i will be definitly building aleph 3
but i cannot stop thinking about zen:>
i will proably try to make my own pcb layout or even use silver p2p wiring instead
Old 3rd January 2003, 06:49 PM   #5
The one and only
Nelson Pass's Avatar
Default Re: Re: update
Assuming that the design is correct, the Aleph X requires
no tweaking, apart from a pot on the current source
feeding the diff pair to adjust the absolute offset DC.
Old 3rd January 2003, 07:58 PM   #6
xsnailx's Avatar
Default thank you nelson...
so lets sum things up:>
1) i have read as much as i can about aleph x but as it is my first experience with aleph amplifiers i will certainly go for a classical aleph
2)at this moment i need to determine wich one
3)i will use one layer pcb
5) i need to find out where to buy sinks and aluminium plates
nd the zen v4 is still on my mind :>
but i dont know if 1 bi amped zen per channel will be enough in my case ???
Old 3rd January 2003, 08:07 PM   #7
xsnailx's Avatar
Default definitly aleph 3...:>
may be not definitly but at 95%
the others i consider are aleph 5 or aleph 30 (aka volksamp 30?) and double zens
Old 3rd January 2003, 09:07 PM   #8
Sparhawk's Avatar
Default Re: Re: Re: update
Originally posted by Nelson Pass
Assuming that the design is correct, the Aleph X requires no tweaking, apart from a pot on the current source feeding the diff pair to adjust the absolute offset DC.
I stand (or sit) corrected, then. I was just going by the discussion in the Aleph-X thread, where there are many warnings to the tune of "this project is not suitable for beginners", etc.
Old 3rd January 2003, 09:14 PM   #9
xsnailx's Avatar
Default aleph x
i have read them too! and decided to go for classic aleph not an x
Old 5th January 2003, 05:10 PM   #10
xsnailx's Avatar
Default It will be ...
aleph 5
but i beg anyone from poland and maybe czech republic please help me
i have some issuse getting proper heatsinks and irfp244
so i will be pleased with every information bout them
ps i will use pcbs from there
http://users.bigpond.net.au/mefinnis...nstruction.htm
are they good or maybe i should use kristjan ones or something else?
hello - a boring intro Spiny Introductions 2 19th February 2008 10:22 PM
never to boring around here karma Everything Else 2 26th January 2006 06:06 PM
Never boring: CCS-Question Onvinyl Parts 2 9th April 2005 07:58 AM
CO2 levels... uhh that boring stuff again roibm The Lounge 40 20th December 2004 12:49 PM
most boring sports Daniel-A The Lounge 27 14th May 2004 12:08 AM
Page generated in 0.11023 seconds (79.82% PHP - 20.18% MySQL) with 10 queries
