diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   how to match devices -help- (http://www.diyaudio.com/forums/pass-labs/93306-match-devices-help.html)
Stefanoo 2nd January 2007 02:49 PM
I'm searching on the forum how to match transistor-jfet-mosfet.
I would like to know...if it is possible do it on your own.
If so, is there any circuit test that i can build and that work fine for the purpose?
hope to receive ...as everytime...your good advice!
best regards,
Stefano.
moe29 2nd January 2007 03:50 PM
which FETS are you trying to match?
is there a particular amp you are going to build?
Check out www.passdiy.com and under the Articles section there is a paper on matching FETS.
Stefanoo 2nd January 2007 04:08 PM
well actually i have to repair my electrocompaniet ECI-4 and i have to replace the transistor (driver and output stage).
Since the configuration is in differential i would like to replace...since i'm have to....with complementary matched type.
The devices that i have to match are BJT (motorola MJL3281A and 1302A and Toshiba 2sa1350y and 2sc3421y).....which i still have to find somewhere...and i hope somebody could help me.
I also found them on the phoenix-components.com...but they since to supply only the industries.
x84andrea 2nd January 2007 04:33 PM
ciao, parliamo in italiano! basta che gli mandi una corrente fissa e calcoli la differenza di potenziale con il mos collegato a diodo,
puoi usare un lm317 in modalita sorgente di corrente e fare le misurazioni, mandagli 500ma o pił!
per fare questo devi dissipare il317 e il mos, se vuoi altro fammi sapere a x84andrea@libero.it
carpenter 2nd January 2007 04:33 PM
If you're talking about basic VGS matching, I saw suggestions in Nelson's DIY op amp article. I have a drawing if you want it.
GRollins 2nd January 2007 04:51 PM
Since they're bipolars, Vgs isn't applicable, unfortunately. That's for FETs. The equivalent measurement for bipolars--Vbe--is quite consistent.
What parameter needs to be matched? Beta? If so, to what spec?
Grey
carpenter 2nd January 2007 06:15 PM
I guess this kind of threw me.:)
DIY op amps also shows how to match bipolars.
Stefanoo 3rd January 2007 07:39 AM
thanks guys for the posts.
I would like to have a little circuit test for matching Bipolar Transistor (mostly) and also have a circuit ...that i guess it's different... for MOS and FET.
I mean.....what do the companies use for selecting their componens? does anybody know it?
Resources saved on this page: MySQL 18.75%
