Parallel Inductors in PSU
Old 1st January 2007, 07:26 PM   #11
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
I want to reduce the voltage out of my Plitron transformers, so, for me this begs the question: if a transformer has two 110v inputs and these are run in series, did I just reduce the V/A rating by half? And, how can I properly use the two sets of outputs?
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 1st January 2007, 07:28 PM   #12
macka is offline macka
macka's Avatar
Hi Dan,
Call up Voller transformers in Melbourne.
He can wind hi current chokes to your specifications.
Macka
Old 1st January 2007, 07:29 PM   #13
carpenter's Avatar
Hi Macka!
Old 1st January 2007, 07:55 PM   #14
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by carpenter
........... if a transformer has two 110v inputs and these are run in series, did I just reduce the V/A rating by half? .............
yes
clarify question,please
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st January 2007, 08:48 PM   #15
carpenter's Avatar
Well, your answer pretty well answers the second question. My 1000 v/a tranny is now 500v/a.
Or: 250 v/a per output tap because there's two pairs of taps...
For the standard ZV7-T, I should probably have more than 250v/a, so the two outputs should be rectified and then paralleled?
Rectified, then CLCLC, then loaded down, I'd probably have 30 volts. From each output pair there's 250 v/a divided by 30, which would give me 8.3 amps. The ZV7-T draws 6amps. So, it will take both taps (16.6 amps) for satisfactory operation?
Did I do this correctly?
Old 1st January 2007, 08:55 PM   #16
Zen Mod's Avatar
in calcs you must start from Vac ratings..........
where Iac=Pac/Uac
so ........mebbe Iac is smthng more than 8.3 calculated
Old 1st January 2007, 09:03 PM   #17
monarodan is offline monarodan  Australia
monarodan's Avatar
Originally posted by macka
Hi Dan,
Macka
Hi Macka,
Any idea what his rates are like? I can get Solen 4.7mH 16GA coils for AU$23 at the moment from Speakerbits (www.speakerbits.com). Their checkout quoted about AU$13 shipping to Perth. That's getting pretty hard to compete with.
I know I can rely on Solen quality. Can anyone vouch for Vollers quality? I should check him out for toroidals also...
Dan
Old 1st January 2007, 09:18 PM   #18
carpenter's Avatar
That would make me very happy. How does that formula work?
Old 1st January 2007, 10:16 PM   #19
Zen Mod's Avatar
lets say that one winding have 250VA
then,say, one winding is 25Vac
in that case -you'll have I = 250VA / 25Vac
I = 10A
play little games with PSUd..........starting with CC load in range of expected..........and then just increase load current in steps,and look what you get
PSUd is in every case smarter than I am.......
Old 1st January 2007, 10:41 PM   #20
flg is offline flg  United States
flg's Avatar
John, Actually that surpised me... But when series'ed and coupled, they are 4X right???
Sorry, I'm a little behind, Let's go back and catch up to my brothers phone connection...
It's not just the phone connection, I'm confused...
trying to catch up from last night I guess...
With the 2 windings coupled but paralelled You basically only have bigger wire and the same turns! Assentialy "BiFilar wound" and equivalent to a heaver guage wire! IMHO!
With the the 2 windings coupled and series'ed you should have 4X the L not 2X
With the 2 series'ed but not coupled you would have 2 X the L
When you have 2 115Volt windings on a 250VA xfmr, why do you think that is??? When you connect the 2 in series, you feed it with 230Volts RMS and get the same VA (more RMS volts but less current) still 250VA You also get 4X the Pri L that way Though
Just my 2Cents...
Parallel Inductors in PSUHide this!Advertise here!
Inductors in series/parallel? QED047 Class D 6 11th August 2009 03:10 PM
Parallel inductors (dumb question) w/ Zobel followup arc2v Multi-Way 11 19th November 2007 08:59 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Does the DCR of parallel inductors matter? Mos Fetish Multi-Way 4 3rd February 2004 10:43 AM
pi filter in class a amp: okay to parallel inductors? jwb Solid State 6 20th October 2002 07:56 PM
