Aleph-X monoblocks finished.
Old 21st January 2007, 10:53 PM   #141
flg is offline flg  United States
flg's Avatar
I agree, the McMillans nay not be the culpret, but their solder joint could be? It seems it's a component that destroys cmrr???
Old 22nd January 2007, 04:49 AM   #142
1001meier is offline 1001meier  Switzerland
Originally posted by flg
I don't see the McMillan R's in that schemo???
2.2K would possibly be the value??? Post #134???
But, then again, those R19-29 guy's???
You aren't running a single ended input are you???
McMillans are installed, so the schematic is slightly different from the original circuit I showed in previous post. First, I resoldered the parts around the CCS but this did not solve the problem. Next, I'll try installing C102 C105. I will post the results later.
Old 22nd January 2007, 04:02 PM   #143
wuffwaff is offline wuffwaff  Netherlands
wuffwaff's Avatar
yes C102 is the one I meant. Donīt forget there are two of them......
Start with something small like 1n or 1n5.
William
een ooievaar is geen konijn want zijn oren zijn te klein!
Old 22nd January 2007, 08:11 PM   #144
William
Here comes a short update of my ongoing chase for the hum in my aleph-x:
1) I inserted C102 and C105 as recommended, but used 10nF instead of the recommended 1nf, since 10nF was the smallest value I had on hand-> no change, same amount of hum
2) Replaced Q3& Q4-> no change, same amount of hum
3) Resoldered all small components around Q3-> around 40% reduction in hum judged by measuring output with scope, amplitude of oscillation is now around 10mV
I also noticed that hum level goes down as amplifier warms up.
Good news is I REALLY like the sound of my aleph-xs the longer I am listening!
Old 22nd January 2007, 08:19 PM   #145
wuffwaff's Avatar
thatīs good news. So I would clean the circuit board and do some more soldering, then clean it again.
William
P.S. donīt forget to remove the caps if they are not necessary!
Old 6th February 2007, 06:27 PM   #146
Default brif update on my chase of the hum
Hi All,
in my attempts to chase the hum out of one of my monoblocks I think I solved the problem- kind of.
After all my fruitless attempts I finally turned my attention to the input section and I exchanged the LTPs (Q5&Q7). The result is a reduction of the hum to a very low level. On my 96 db efficient speakers you can only hear it within 1m from the speaker. Funny thing is when I look at the output with my scope, I now see almost the identical amount of hum on both sides, i.e. the - side that had before been absolutley silent now has the same amount of noise as the + side. (both sides now look like the lower trace in the picture of my post #123). I guess the result is that the X-configuration now rejects the common noise quite efficiently....
Old 30th August 2008, 04:24 AM   #147
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by Zen Mod
locall time - 2320
this is Zen :
(again-be happy ,all of you )
how cute, Zen Mod
looks like a father and child image
http://www.diyaudio.com/forums/attac...amp=1167603488
lineup
Old 3rd September 2008, 03:41 AM   #148
jpc6204 is offline jpc6204  United States
The beauty of symmetry!
Old 15th September 2015, 08:35 PM   #149
reggieSf25 is offline reggieSf25  United States
Where did you source the heat sinks?
Old 20th September 2015, 02:15 AM   #150
man, they are beautiful
Aleph-X monoblocks finished.Hide this!Advertise here!
AX100 100W Aleph-X Monoblocks gl Pass Labs 635 23rd October 2012 05:25 PM
FS/FT: Fully Built Aleph-X Monoblocks [AUS] kenny12 Swap Meet 14 18th May 2009 11:03 AM
Aleph 3 monoblocks for sale cowanrg Swap Meet 4 17th April 2007 04:37 AM
6 monoblocks finished Cro maniac Chip Amps 17 14th January 2006 07:50 PM
Copyright ©1999-2017 diyAudio
