Old 29th December 2006, 01:09 PM   #1
Send a message via ICQ to AudioAngel
Default Balanced Zen Line Stage Output Impedance?
Hello!
I'm right if I say the output impedance of the Balanced Zen Line Stage will be ~1.5k (twice the 750ohms load resistors) in balanced in/out-mode?
Greetings,
Raphael
Old 29th December 2006, 02:06 PM   #2
eLarson is offline eLarson  United States
eLarson's Avatar
Do you have resistors from the output node to ground, too?
Would a woodchuck bother to chuck MDF?
Old 29th December 2006, 03:30 PM   #3
Yes but I'm ignoring them at the moment. I think they will increase the output impedance so the impedance will be 2x750ohms + 2x 221ohms = 1942 ohms right?
Raphael
Old 29th December 2006, 03:57 PM   #4
MikeW is offline MikeW  United States
MikeW's Avatar
http://www.passdiy.com/legacy.htm
The output impedance will go down with resistors to ground. So will the gain.
MikeW
Old 29th December 2006, 04:12 PM   #5
flg is offline flg  United States
flg's Avatar
I believe the 221 ohm Rs you are speaking of are in series with the output, not to ground...
Ignoring those for the moment, I believe your output impeadance will be close to 1500 ohms balanced. Actually slightly less
Old 29th December 2006, 04:29 PM   #6
Yes, you are right. My mistake.
I'm only interested in the pure output impedance. So my first idea seems to be right if you say 1.5k.
Raphael
Old 29th December 2006, 07:38 PM   #7
eLarson's Avatar
1500 ohms is probably close enough, if that's all you were looking for.
Tube line stage output impedance regal Tubes / Valves 28 21st July 2010 12:40 PM
Line-Stage w/ balanced output denny9167 Tubes / Valves 11 22nd January 2008 12:16 PM
Balanced line stage- input or output attenuator nobody special Pass Labs 4 7th April 2006 01:18 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
Output Capacitors for Balanced Zen Line Stage scrazy Pass Labs 1 14th June 2001 02:55 AM
Page generated in 0.08163 seconds (73.19% PHP - 26.81% MySQL) with 10 queries
