Hello,
just read the paper on firstwatt.com concerning the filter networks for a constant current source amplifier like F1. But I'm a little bit confused about getting the part values. Therefore can somebody explain it to me so that I an verify my thoughts? Let's say, we want to build an 2nd order Bessel filter with a cutoff frequency of 1kHz and 1K ohm load (just as an example). What re the component values? Greets, Raphael |
#2 |
The one and only
Referring you back to that article, on fig 5A you see a 2 pole
high pass and low pass network (in series) both of which are set for 1 KHz. You need only multiply the inductance values by 125 and the divide the capacitor values by 125 to scale the 8 ohm load to 1 Kohm. You can use these two networks alone - each does not require the other. The specific alignment of can be tweaked with modest variations, and of course you can multiply/divide values of the inductors and capacitors to scale the filters to other frequencies.
#3 |
Ok, thank you Nelson.
I didn't recognized that they are set to 1kHz. So the only way to get the desired Bessel characteristic is try and error unti it fits in? Raphael |
#4 |
The one and only
If you are mathematically inclined, you can calculate the
exact LC values. I don't personally get excited about this when we are dealing with loudspeakers - precise filter types are not usually optimal due to the vagaries of the driver response.
| Constant current source, am I missing anything... | gmphadte | Power Supplies | 4 | 3rd August 2007 04:07 AM |
| constant current source | hacknet | Solid State | 19 | 13th March 2006 02:46 PM |
| Constant current source for Clone | audioandy | Chip Amps | 2 | 27th January 2004 11:55 AM |
| Constant Current Source article (Old) | tvi | Solid State | 8 | 11th September 2002 01:44 AM |
| Constant Current Source Circuit | mrfeedback | Solid State | 8 | 22nd April 2002 05:07 PM |
| Page generated in 0.07949 seconds (72.70% PHP - 27.30% MySQL) with 10 queries |
