Looking to build my first Class A amp, either a ZenV9 or Aleph 30. Havn't had much luck finding heatsinks though. Best prices I found were from Conrad heatsinks for their MF35-151 pieces. Only problem is the 12 weeks it is going to take to send them by sea freight. So before I make an order I was wondering if anyone wants to sell any of their extra heatsinks or cases? Or does anyone have some more local options for heatsinks? I've tried Rtheta but their minimum order is too large for a single amp.
Thanks Chad |
#2 |
Hi Chad,
I have some 11" x 11" R-theta heatsinks. I used the same ones for an Aleph 30 a while back: http://www.passdiy.com/gallery/aleph30-p2.htm Please email me for more details. Cheers, Dennis |
#3 | |
Hi Dennis, I'm also interested getting 4 of such heat sinks. Please let me know if you still have some left after Chad gets what he wants. Thanks. |
#4 |
For an Aleph30 you cannot beat the Conrad Heatsinks model MF35-151. http://www.conradheatsinks.com/produ...at100_350.html
The amp will run at it's optimal temperature after many hours of use. Take their C/W rating and multiply a correction factor of 1.4 for the C/W at room temperature. Do a search on this forum for this manufacturer and you will find many positive comments about their prices and service. Here's a link to my Aleph30 with these sinks to see them in action. My 1st Aleph Amp Good Luck, -David |
#5 |
David,
Is that frosted glass for the front panel? Looks nice. I've thought about doing the same. How did you make it (or get it made)? I've considered the Conrad heatsinks you mention, but they seem not up to the job for a Zen V9. How much does your Aleph 30 dissipate? I'm currently planning to use a pair of the MF18-151.5s with the fins pointing at each other, augmented with a (hopefully quiet) fan. I'd also be interested in some R-Thetas if I could find a pair. |
#6 | |
I ordered some Conrad heatsinks in a DIYaudio group buy earlier this year. They were shipped "sea freight" but I received them within a couple of weeks. They had a sticker with "economy air" stamped on it. So your order "might" not take that long. |
#7 | |
Hi Paul, I did not need a fan with a pair of the largest Conrad Heatsinks. The amp passes the "hold your hand on the heatsink" test for 5-9 seconds depending on the ambient room temperature. It's really nice not to have to use a fan and eliminate any background noise. A pair of MF35-151's should work with both amps. The chassis was a sheet of aluminum ordered from FrontPanel Express and bent into a U shaped shell with the heatsinks tapped and bolted to the chassis. A very strong and rigid chassis. The front panel is 1" thick Lexan that was frosted with an orbital sander. The details are in this link: My 1st Aleph Amp One other aspect of the Conrad products is they are black power coated rather than anodized. They will never turn color and dissipate heat a little better. -David |
#8 | |
Steen
#9 |
Thanks Steen for the compliments. I recessed the hex head bolts and the blue light switch with a forstner bit on a drill press. What's really cool is when the room lights are off the frosted panel glows a dim light blue.
-David |
#10 |
So everyone thinks the biggest conrads will work for the v9?? Good to know because I think that is what I am going to use..
| To-3 Heatsinks | sandstorm33 | Swap Meet | 8 | 6th February 2008 04:33 PM |
| about heatsinks | bigpanda | Solid State | 2 | 4th May 2005 03:34 PM |
| Heatsinks | DD_Davo | Chip Amps | 2 | 13th April 2005 01:00 PM |
| Heatsinks | Peter Daniel | Swap Meet | 19 | 3rd February 2004 11:08 PM |
| Heatsinks for DoZ | ultrachrome | Solid State | 0 | 4th February 2003 09:23 PM |
| Page generated in 0.11280 seconds (82.21% PHP - 17.79% MySQL) with 11 queries |
