Hello forum
I am spirit to build the ALEPH 2. I shall like to know if it is necessary to isolate the standard(cannon) of the IRF 9610 to go(take) up them on heatsinks, not to put them in the ground Happy new year for all
stay zen |
#2 |
I'm not quite sure what you mean. The fet's do not need to go on the main heatsink but should be seperate from it.
#3 |
In fact ,
I put small radiators on the 9610 but I do not have to isolate the standard(cannon). I wanted to know if it is necessary to isolate. @+
stay zen |
#4 |
I think I understand now. It is good to put small heatsinks on the small fet's and you do not have to isolate them from the heatsinks, as long as they do not touch anything else.
Happy Building! |
#5 |
then I do not know or is my problem.
I test the exit HP is I have a D.C. current. I don't find the breakdown .
stay zen |
#6 |
Give us some voltages. Source resistors. Where is the current you are measuring? Across the output? are you using a resistor across the output? More information please. I'm finishing up my Aleph 2's also today.
#7 |
I wonder how much difference it will make to mount the
IRF9610's forming the differential pair (Q1 and Q2) back-to-back on a single heatsink for better thermal tracking. In this case, the devices will need to be electrically isolated. Dennis |
#8 |
Here is another thread to read
My Aleph 5 isn't working |
#9 |
I have use the same diagram that "Wayne" with the same value of the components. at exit I then have a D.C. current which goes up, I quickly cut off the supply.
stay zen |
#10 |
It sounds like a thermal problem. How big are your main heatsinks and did you match your mosfets well? How are they mounted to the heatsinks?
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.08750 seconds (76.74% PHP - 23.26% MySQL) with 11 queries |
