diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Aleph wire routing question (http://www.diyaudio.com/forums/pass-labs/92646-aleph-wire-routing-question.html)
D97GT 22nd December 2006 03:48 AM
I am wiring up my Aleph 5 on the bench this weekend. I was going to use a good quality 14 AWG copper 4 conductor cable that I have to wire the driver pcb to the output pcb. I was wondering if its a problem bundling the low level signal wires (sense/gate) with the high current ones (source/drain)? Any issues with noise or anything like that?
MRupp 22nd December 2006 08:43 AM
I would separate the gate/sense from the source/drain leads and if possible keep the gate totally separate. The drain/source leads carry the amplified signal currents which could feed back into the gate and cause extra distortion and possibly oscillations.
While we're at it, I would also keep all signal carrying leads at some distance (at least a few millimetres) from any metal surface (casing, heatsinks, etc.).
My 2 cents....
D97GT 22nd December 2006 08:32 PM
Thanks, Thats what I needed to know!
Copyright 1999-2017 diyAudio
