L Loaded ZV9 Help???
Old 15th December 2006, 04:26 PM   #21
flg is offline flg  United States
flg's Avatar
Babowana, in both Ls, the square waves only "overshoot" at the low freqs. The rising edges begin to get rounded at higher freqs. The "overshoot" and rounding, does look realatively symetrical...
Also, I do not have the feedback resistor bypassed with the 10p C as Nelson sugests in ZV9 (it should make the square with look better). I beleive this will only help the high end though and in the opposite way??? I can try a C though. I also think varying the gain/feedback might be worth a try
Fuling, That 800VA Toriod is the biggest thing I have in Toriod... I tried lowering the Iq a little (25%) when I saw that but I saw little difference
Old 15th December 2006, 04:39 PM   #22
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
I would increase the 470uF to the greater than 1000uF
Anyhow, very good
Old 15th December 2006, 04:56 PM   #23
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
I think you'd be much happier with an air-core choke. I sure am. To keep the resistance down, I use my amp in the mids and up. This allows me to use a smaller choke.
I'm going to put my amp under the scope today.
I'd like to know more about PC based analyzing software.
You're having fun and sharing an excellent tail with the rest of us. That's what I call priceless.
John
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 15th December 2006, 06:12 PM   #24
flg's Avatar
So John, I guess your weather is clearing up out there? Perfect DIY weather though Ha???
Yes, I guess I'm having fun...
At lunch I think I figured out some of my problem, I think...
In all my excitement to bench test, I don't have some of my typical stuff on this amp. I'm powering it with my 'ol standby rack mount switcher. Well I generally have 5-10mF of C on my boards right near the output transistors and I don't have a board for this one... So, I figured out while at lunch, I am probably seeing the transient response of my 'ol standby switcher supply in the output response of the amp??? I was a little hesitant to call it "overshoot" cause it's not quite overshoot looking and it just transfers from overshoot to rounding of the leading edges of the squarewave across the frq band???
I can look at the supply line first(shame on me) or, I'm going to hang a big cap or two on the switcher output, with a film or two, and see what the output looks like then??? I'll bet it gets right back in line with what it should look like...
First I gotta take Mom and go visit dad in the Hospital... Congestive heart failure and emphasema...
Ho Ho Ho Buddy
I'll get back to ya on the PC based Audio Anal Software
Old 15th December 2006, 06:20 PM   #25
flg's Avatar
Babowana, Yep, I thought about that too And, that C kepps the amp on a real slow turn on too. But that power supply thing sounds more likely an important thing to correct first... I really have no idea what that supplies out Z, or transient response is
Old 15th December 2006, 07:30 PM   #26
flg's Avatar
Well, I doubled up on the cascode refrence bypass (2 x 470uF) and I added a 22,000 with a film to the choke input No change in the square wave response
Actually, the waveform is not exactly symetrical??? See below???
I can look around "the playroom" a little more for another xfmr... Or, I have a Lincoln arc welder transformer in the basement???
I can also switch to a resistive load and see what happens with that
Old 15th December 2006, 08:40 PM   #27
carpenter's Avatar
Resistive load; good thinking.
Old 15th December 2006, 08:45 PM   #28
Fuling is offline Fuling  Sweden
I think the best inductor in this circuit would be an iron cored one with airgapped core. Hammond has a few that would work, Iīd go for >150mH.
Old 15th December 2006, 08:49 PM   #29
flg's Avatar
Yes, Hammond had some with High DC current specs. They are $50+US though. Do you have a specific part number? Are we thinking about the same type???
Old 15th December 2006, 09:47 PM   #30
I donīt remember the part numbers, but I know there are one or two in the 193-series that should be suitable for this kind of job.
Iīve messed around a bit with inductor loaded amps and itīs a great way to get serious power out of single ended circuits.
L Loaded ZV9 Help???Hide this!Advertise here!
Front loaded and back loaded horn DrWoofer.com Subwoofers 14 12th April 2016 08:32 PM
Choke loaded LTP jane Tubes / Valves 6 8th November 2008 02:25 PM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
Slot loaded PR DAMIC Multi-Way 0 17th April 2008 06:48 AM
Loaded Question dr._sleep Tubes / Valves 2 23rd November 2005 09:23 PM
Copyright ©1999-2017 diyAudio
