Old 28th December 2002, 06:07 PM   #1
dshortt9's Avatar
Default Aleph 2 construction help
I'm building Aleph 2's. How close (far away) should an input fet be from a toroid so it does not cause hum? is 2" ok?
Old 28th December 2002, 08:04 PM   #2
dshortt9's Avatar
Any educated guesses are welcome. No Liability. I can change it later easily if it hums. It just looks better this way if 2" will work.
Old 28th December 2002, 08:24 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
This is not an easy guess. It depends on many factors (type of toroid being one). I'd say it's OK, and when it hums just move it further away. But I doubt if the distance will make any difference.
You can also try to shield toroid with a copper tape.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 28th December 2002, 10:00 PM   #4
dshortt9's Avatar
Thanks, Peter. At least I know I'm in the ballpark.
Old 29th December 2002, 03:55 AM   #5
My toroid and pcb are at opposite ends of the chassis....but then my chassis is radically different from what most of you have done anyway.....I could have put the pcb and transformer next to each other, but it didn't make sense. I have a very small amount of hum and may try surrounding the toroid with a copper ring, or having some steel cans spun to enclose them completely for best shielding. Needless to say the front panels and anodizing are still to come......
Mark
Old 29th December 2002, 04:11 AM   #6
dshortt9's Avatar
Thanks, Mark. Your amps look great!
Old 29th December 2002, 06:34 AM   #7
Thanks! I just finished the second one and have had it on-line now for just over an hour........You will never regret building yours. I just improved my system about 5000%......
Both amps worked fine on forst power up too and that makes me really happy.
Nelson.....You Da Man!
Mark
aleph 3 construction (it's me again!) ShanaVar Pass Labs 5 24th February 2007 03:56 PM
Another Aleph ?? under construction.. blank527 Pass Labs 25 10th December 2002 09:57 AM
Aleph 2 construction problem! alexmark Pass Labs 1 14th October 2002 05:54 PM
Aleph 2 construction issues Luke Pass Labs 26 7th October 2002 09:01 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.09168 seconds (73.80% PHP - 26.20% MySQL) with 11 queries
