i want to put choke in the power supply..what value should i put?
i believe by doing so..the dc current will be increase..pls correct me if im wrong?pls advice...thanks. rgds tone |
#2 |
The one and only
A pi (CLC) type filter would be appropriate. 1 to 2 mH
is a good value, and it must be a big coil with thick wire, not a tiny coil, rated at 10 amps or so and .1 ohm or so. It will not increase the current, but it will reduce noise on the supply, and thus noise coming out of the amplifier. |
#3 |
Hello Nelson,
i have two toroid transformers rated 300va 2x25volts 6A, can i uses this..im worried that i do not have enough current..is this good enough?. rgds, tone |
#4 | |
A 2.0 mm^2 3.9 mH is still 0.4 ohm (and costs 37 euro )Guess that means using a HQ core coil like (1.15 ohm for a 1.5 mm^2 3.9 mH) costing 12 euro. ![]() Or maybe this torobar thing (looks funny) 0.17 ohm for a 3.3 mH )costing 19 euro) ![]() Still some people I know say air cores are much better?? iron/ferro etc. cores get very hot or something? Still wondering how critical the mH value is. Nelson always mentions 1-2 mH, Kristijan says 3.9 mH (which is much more expensive). ps never understood how to interpret the "gauge" wire indication. We just use surface area of the wire in mm^2.
Is that all there is? |
| Choke rating for choke input duty | cbutterworth | Tubes / Valves | 14 | 9th November 2007 04:43 PM |
| Swinging choke vs std. choke in PS | Curly Woods | Tubes / Valves | 2 | 5th March 2007 08:30 PM |
| Swinging Choke or Smoothing Choke | danFrank | Tubes / Valves | 4 | 11th February 2007 11:05 AM |
| Fender amplifier.. burnt choke ?? | rainerm_au | Tubes / Valves | 2 | 22nd February 2005 10:21 AM |
| PSU choke value | trancy | Tubes / Valves | 8 | 9th March 2004 03:56 AM |
| Page generated in 0.07566 seconds (74.79% PHP - 25.21% MySQL) with 10 queries |
