DIY F2 clone - Page 53 - diyAudio
Old 19th August 2015, 10:31 AM   #521
maxlorenz's Avatar
Dear Mr. Pass, Zen Mod and fellow DIYers,
I suspect some (most?) of the fine sonic attributes of tube amps come from the use of tube rectifiers...if only we could use them for SS amps...
Has anybody knowledgeable played with Thyratrons?
Thyratron Rectifiers
Thanks,
M.
Old 19th August 2015, 11:11 AM   #522
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
naah
no benefit (all drawbacks) and too complicated
even for my level of insanity
(had experience with big tube rectifiers , in cinema (Xenon))
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th August 2015, 01:17 PM   #523
maxlorenz's Avatar
OK. Thanks. That saves me a lot of study.
Another clever trick that I've used, both in low power and high power circuits, is -ECdesigns'- stteped rectifier.
Diodes and R values can be upgraded/increased to meet desired power ratings.
M.
Old 19th August 2015, 07:37 PM   #524
oks81 is offline oks81  Norway
Originally Posted by Zen Mod View Post
I believe answer is somewhere in article
Output impedance for my F2:
Reading, reading, reading
Found in articles:
Zen Amp: 1ohm
Zen Lightenment: 1ohm
Zen Variation 2: 1ohm
Zen Variation 8: a little less than 8ohm.
Original First Watt F2 without R13,14,15: 700ohm
On page 15, post #141 in this thread i find that output impedance for my F2 should be "big R" in parallel with output resistors R13,14,15.
I`m only using R13, and big R is 5ohm so finding output impedance=4,5ohm ?
Is this correct teacher Zen?
Old 19th August 2015, 09:07 PM   #525
Zen Mod's Avatar
it's here , top of page 7 :
Old 19th August 2015, 09:27 PM   #526
Found in articles:
Yes, that is correct. When big R and R13 is in parallel you find the total resitance, Rtot, with this equation (I saw in a previous post that you used 47 Ohms for R13):
Rtot = 1/((1/BigR) + (1/R13)
Rtot = 1/((1/5) + (1/47) = 4.519 ohms
I hope it is ok that I reply, even thought I am not master Zen :-)
Old 19th August 2015, 10:24 PM   #527
Zen Mod's Avatar
Old 20th August 2015, 05:56 AM   #528
Thanks a lot to both!
F1 Clone DIY PCB suds Group Buys 2 8th January 2009 09:50 AM
My F3 Clone 04dgmsilv Pass Labs 11 31st August 2008 11:59 AM
clone AN/K ccopp Multi-Way 0 9th July 2006 08:24 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
