DIY F2 clone - Page 50 - diyAudio
Old 28th July 2013, 05:52 PM   #491
OllBoll is offline OllBoll  Sweden
Nice, I think I'll do just that =)
Old 11th January 2014, 03:59 PM   #492
I just hooked up an F2J with a Hammond 193V as per post #482. The plan is to compare the sound of the F2J to my L'amps, they are both similar but at the same time different so will be interesting.
The 193V gives a mad efficiency boost to the F2J, my last highest power on the F2J was with 48V rails and then I got ~ 6.5W into 8 ohm. Here I use 24V rails and I get 10W clean with no higher order distortion than 2nd + 3nd into 9.4 ohm, so probably around 12W into 8 ohm. Considering that the vanilla F2J only achieves 5W into 8 ohm I guess big inductors as current sources are pretty nice =)
The current is currently 2.18A and ~ 20.5V drain voltage so about 45W dissipation on the R100 which is ok.
Old 11th January 2014, 05:58 PM   #493
I just did some distortion comparisons on some speakers with the F2J ( 200 ohm in parallel instead of 15.66 so ~ 150 ohm output impedance ) vs L'amp for those who are interested in the L'amp thread.
Old 13th January 2014, 07:49 PM   #494
Hmm... currently the R100 is running at 20V @2.25A => 45W... sounds a bit high or what do you others think? Heat isn't a problem, I can hold my hand on the sink indefinitely but I don't want the jfets to break in the long run =)
I have two matched pairs so I'm considering upping the source resistors to 1 ohm and then do ~ 1.2 - 1.5A on each for ~ 25-30W dissipation on each jfet. My 193V inductor is capped at 3A so I can't go higher than that.
I do have a lot of heatsinking though so I could also double the voltage to 40V at jfet drain and run each device at 35W instead. The question is if I would get power into the right impedance, the speaker is 10-20 ohm with an absolute minimum of 9.5 ohm.
Old 13th January 2014, 07:57 PM   #495
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
if it's cooled properly , there is no fuss with 45W
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 13th January 2014, 07:58 PM   #496
That's good to hear, then I'll probably leave it as it is since it works so well at the moment.
Old 19th April 2014, 07:33 PM   #497
When I re-built two inducted F2Js with the mod for more current I think I had the pot turned in the wrong direction and killed them both on turn-on.
So now I thought I might confirm how enchantment mode should be used to conduct 0 current. Depletion JFETs conduct close to nothing when gate is very negative compared to source, and conducts more the higher V at gate. And if I understand correctly now enchantment mode JFETs conduct nothing if source = gate, and more current the closer gate voltage is to drain voltage?
Old 20th April 2014, 07:22 PM   #498
I think I've found the culprit!
Though the main dumbness was from me =) The biasing of the F2J is of course tailored for ~ 12V drain voltage and I slammed it with 24V so even at lowest setting of pot the gate voltage got too high and the R100 tried to conduct too much current. I copied the arch nemesis bias supply instead which also has that handy zener to bring down the voltage and now it works =)
I did some tinkering first though, didn't want to blow another SS JFET so I chucked in an old IRF240 to ensure that the rest of the amp worked as intended first =)
Old 21st September 2014, 02:04 PM   #499
What is the purpose of R1 in the schematic of First Watt F2?
It can be skipped?
The amplifier performance or the input impedance will be affected if R1 is skipped?
Old 21st September 2014, 08:07 PM   #500
Zen Mod's Avatar
bleeder for C1
clever to keep
use anything between 470K-3M3
F1 Clone DIY PCB suds Group Buys 2 8th January 2009 09:50 AM
My F3 Clone 04dgmsilv Pass Labs 11 31st August 2008 11:59 AM
clone AN/K ccopp Multi-Way 0 9th July 2006 08:24 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
