Old 13th July 2012, 04:01 PM   #451
OllBoll is offline OllBoll  Sweden
Originally Posted by Lazybutt View Post
Everything is possible within reason... or rather ... within components specs.
With such a simple circuit, you can play with U and I by just playing with components values.
Just check Umax and Pmax of every components, and keep a safety margin.
I is set by R16//R17 in the current source... if it's not obvious to you (it wasn't to me), read the Zen Amp series articles to understand how, but in essence, increase R16//R17 to reduce I
Nice, thanks for answering =)
I've read the Zen articles which is what gave me the idea since Nelson experiments with lots of different voltages and the F2 is if I remember correctly based on the Zen. I'm no electronics expert though so I thought I'd also ask to be sure
So now another question if someone knows, is current linear in proportion to R16/R17 or is it some exponential whatnot such that I ideally need a pot to dial in amount of current?
Old 13th July 2012, 05:28 PM   #452
cochleus's Avatar
It is inversely proportional. That is; I=0.66/R or, R=0.66/I
Read first Zen article for describing this type of current source in better detail.
"My desire for knowledge is intermittent; but my desire to bathe my head in atmospheres unknown to my feet is perennial and constant". --- Thoreau
Old 13th July 2012, 06:19 PM   #453
cochleus's Avatar
In other words it's just simply Ohm's Law. R16/R17 are current sensing resistors. The circuit is designed to keep the voltage drop across R16/R17 at 0.66V.
Old 2nd December 2012, 02:42 PM   #454
Red face F2J DIYer needs help
Hi, I've been a 2A3 amp user a while but like to go SS with the F2J...... keep hearing about boards available from Daniel.. how do I get in touch with him ? And is Bias adjustments etc. requiring a lot of equipment ?
Lot of Thanks, Mike
Old 2nd December 2012, 02:59 PM   #455
flg is offline flg  United States
flg's Avatar
Audio Sector - diyAudio
Peter Daniel
Or PM from the Forum
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 2nd January 2013, 03:44 PM   #456
Hello there again,
I'm considering adding an input transformer since I have a balanced source. If I've understood correctly the Jensen JT-11P-1 works well for this area.
So now the question: The Jensen is 10k:10k, and the F2J has 10k input impedance so I should just hook up the trafo before the F2J without putting any extra resistors on either side?
Thanks in advance,
Olle
Old 2nd January 2013, 07:42 PM   #457
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
most probably
don't be lazy - put link to datasheet , so we can check it together
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 2nd January 2013, 08:17 PM   #458
Forgot that =)
http://www.jensen-transformers.com/datashts/11p1.pdf
Old 2nd January 2013, 08:41 PM   #459
Zen Mod's Avatar
just go with typical application pic , having R1+C1 combo across secondary
Old 16th January 2013, 07:05 PM   #460
Just powered up and measured my F2J with the input trafo and 48V rail voltages and halved current
Max clean output @ 8 ohm is ~ 4 Vrms so 2W if I've understood correctly.
Much more than 24V but still not a lot and hoped for more, I think it will be enough though since it will drive 300 and upwards with 94 db efficient drivers.
F1 Clone DIY PCB suds Group Buys 2 8th January 2009 09:50 AM
My F3 Clone 04dgmsilv Pass Labs 11 31st August 2008 11:59 AM
clone AN/K ccopp Multi-Way 0 9th July 2006 08:24 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
Copyright ©1999-2013 diyAudio
