#401 |
The one and only
It's always something.
#402 | |
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#403 |
Could I replace gate resistor of the Semi JFet with a 56ohm with out making any other adjustments besides the Pot adjustment?
#404 |
I think that is no problem!
and the First W tt is......a really First Class P SS Idea !
#405 |
I think I was a little rude not introducing myself before asking for anything.
I've read a lot on the different forums on Diyaudio and try to contribute when I think I could be helpful. I have to say this is the best hobby I've ever gotten into. I'm not a techie or even very smart but there is enough info on these forums where if anyone "really wanted" to achieve building one of Mr. Pass's kindly donated schematics it is truly achievable with in that persons capabilities. There is so much to learn and understand(this one might take a while) but the end result is very satisfying. I'm constantly browsing the sight and studying on what I would like to build next or just read. I'm very thankful to all who contribute to Diyaudio because with out this site I would have never had the confidence to get into this wonderful hobby. I don't talk much but I'm on here almost every day. I usually don't speak because if I do, it will most likely be questions and 99% of the time it has been ask already. Thank you in advanced for any help. Eric |
#407 |
Oh! didn't realize... thank you generg and thank you Tea-Bag for pointing that out to me.
Well, the reason I am curious is I'm purchasing some naked vishay resistors from a gentleman on the swap meet. This would be my main reason why I wanted to know. Well since I'm here, would it be almost as critical to have quality resistors on R6, P1 and R4? I was also curious about turn-on thump. For my F5 I used thermistors on both the hot and neutral for turn-on surges(works great by the way). He mentions this in the Zen 5 article but would this work for the F2J? Thanks again
#409 | |
Sorry to bring up an old post, but I just got out my old SemiSouth F2 amp and was checking things on it.. Basically, isn't the bias supposed to be exactly 1/2 the voltage of the amp? So, for me, I've got exactly 22v coming from the PS feeding the amp, and I've got my bias at 11v. I thought it had to do w/ keeping the signal square and balanced. Or, am I wrong, and the bias is only adjusting how hot we're running things, so a bit more, if the heatsinks can take it, might be better? I'm wondering because I've got huge heatsinks, and can definitely run things hotter. The amp barely gets warm the way it is. I like the idea of running things hotter if it could help. (I don't have test equipment for this, so I want to go for whatever is generally considered best practice) Thanks |
#410 |
Bump, for above question. I let it go for a while 'cause I thought maybe it was just a dumb question.. but I re-read this thread and there is conflicting info it. One of the early pages says to do it the way I have it.. exactly 1/2 the input voltage (I usually work w/ tubes, so 1/2 b+).
But later in the thread there is talk about pushing it to run hotter, implying higher bias is better if your heatsinks can take it. Which is it? Thanks |
| F1 Clone DIY PCB | suds | Group Buys | 2 | 8th January 2009 09:50 AM |
| My F3 Clone | 04dgmsilv | Pass Labs | 11 | 31st August 2008 11:59 AM |
| clone AN/K | ccopp | Multi-Way | 0 | 9th July 2006 08:24 AM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
