Old 25th November 2006, 09:45 AM   #1
yoke is offline yoke  Croatia
yoke's Avatar
Default New AlephX - problem
Hi...
I have put together two channel of Aleph X...
One is working fine, except that heatsinks are little short so that temperature is 65*C, but the another gives me problem...
I just connected it for the firs time...and one side doesn't work?
When I say one side, I mean, when we divide this amp to + and – output side...Q1, Q2 doesn't work...Q10, Q11 does work...( I have 2xQ1,Q2 and 2XQ10,Q11 )
I measure voltage over source resistors on those mosfet and I get 0.5V on Q10, Q11 and 0V on Q1, Q2...
I try to swamp Q5 and Q7 and I get same thing...
What could be wrong?
Old 25th November 2006, 10:15 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
What's the voltage over R23 and R25?
/Hugo
Old 25th November 2006, 10:21 AM   #3
yoke's Avatar
R25 2.9 and R23 4.6 at around +/-12V
Old 25th November 2006, 10:40 AM   #4
Netlist's Avatar
R23 is correct. 2.9V over R25 is not enough to turn Q2 on. So, you'll have to find out why that voltage is too low. Correct resistor value? Bad soldering?
/Hugo
Old 25th November 2006, 11:21 AM   #5
yoke's Avatar
could it be that Q4 or Q9 ( ztx450 ) are broken ?
Old 25th November 2006, 12:01 PM   #6
Netlist's Avatar
Could be, just take them out for the moment, the amp works fine without them.
In any case, you need exactly the same voltages at R23/25 and 2.9V is too low. Measure the voltage across the gate resistors of the output and current source mosfets.
They all should read 0V. If not, the corresponding mosfet is broken.
/Hugo
Old 25th November 2006, 12:51 PM   #7
yoke's Avatar
o.k....I replace ztx450...no change...
Change Q7 ( IRF9610 ) on R25 (¨the one that measures less then 0.4V ) ... no change...
I try to resoled resistors around Q5/Q7 ( on PCB )...no change...
Is there possibility to burn something while playing with this...I mean one side work, other don’t and there is above 10V on PCB ?
Netlist, thanks for your time and hlep
Old 25th November 2006, 12:55 PM   #8
yoke's Avatar
upppsssss
I just soo that I have solder R8 into the place of R7
Old 25th November 2006, 01:00 PM   #9
Netlist's Avatar
Again, what voltage do you read across the gate resistors of Q1 and Q2?
/Hugo
Old 25th November 2006, 01:09 PM   #10
yoke's Avatar
everithing is fine now...
thanks Hugo once again
it takes me only 3 and a half hour to figure that I solder resistor at wrong spot
AlephX PSU- need help bach2800 Pass Labs 6 6th July 2006 09:53 PM
AlephX board OK? mchapman Pass Labs 3 13th June 2006 12:16 AM
AlephX with 610? ijomojo Pass Labs 3 1st September 2005 04:45 PM
Best 1st amp:AlephX, 5 or a Zen? rif Pass Labs 7 15th April 2004 04:56 PM
IRF 230 or IRFP 140, what's better for AlephX ? Peter Daniel Pass Labs 29 26th September 2002 03:05 AM
Page generated in 0.09232 seconds (85.59% PHP - 14.41% MySQL) with 11 queries
