I'm a bit of an audio newbie, but I've always been curious - why no kits of the "SEWA" low-power class-A amplifier?
With a similarly simple class-A preamp, a whole amplifier could be made for under $100, assuming a suitably ginormous power transformer could be sourced from something broken. |
#2 |
Teapot,
Take a look at Mark's Class A MOSFET Amplifier. It looks fairly simple. To cut down on costs, don't use a choke in the PS and perhaps you can try car bulbs instead of the big power resistors. Use a breadboard for the circuit and the parts should be able to buy at a local electronics shops. For a big transformer, look around for a dead computer UPS. Cheers.
DIY Audio Projects [ 10" DIY Subwoofer | FE127E Sealed Bipole | [ LM3886 Chip Amp / Gainclone | K-12M Tube Amp Kit ] |
#3 | |
Getting the parts is no problem for me. However, I'm surprised that, considering the low parts count, nobody has made a small PCB on which all the small components can be mounted. Olimex will make something like 12 1"x2" double-sided boards for about 26$. Yes, I'm aware that I could just build one myself, but ordering one or two of every part gets expensive - and my point-to-point skills are lacking. |
#4 | |
I don't imagine that there would be much demand for such a small PCB. If you use a protoboard you get much more felxibility in being able to fit locally available parts or parts you have on hand. Furthermore, a protoboard can be purchased locally and at a fraction of the price. You should be able to get a protoboard for the price of shipping a PCB. You should not have to order any parts unless you want to use a very high quility MOSFET. There is not much more skill required for doing a protoboard project versus a PCB.
#5 | |
| SEWA - Seven Watt Amplifier | Mad_K | Pass Labs | 928 | 27th January 2012 05:01 PM |
| Page generated in 0.07507 seconds (78.52% PHP - 21.48% MySQL) with 10 queries |
