Short the Output of an Aleph X
Old 19th November 2006, 07:17 AM   #1
rsbay is offline rsbay  Germany
Default Short the Output of an Aleph X
Hello,
I want to implement a relay to short the output of the Aleph X amplifier during run up and as a security device for my loadspeakers when the differential offset gets to high.
There are two ways of doing it :
1. short the plus and minus output to ground
2. short the plus and minus output together
Can I use one of both ?
Ralph
Old 19th November 2006, 08:33 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
A carefully build and aligned AlephX should be stable within the 100mV range offset.
The McMillan resistors and the big output resistors to ground will greatly help in stabilizing the DC.
Besides that, Im not sure relays are happy with switching DC voltages in the long run.
As far as I know, there are no reports of AlephXs who ever damaged speakers so Id concentrate on good and careful alignment instead of output relays.
/Hugo
Old 19th November 2006, 08:52 AM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Or stick a non-polar electrolytic cap in series with the speaker.
-- Yeah... I know.... sorry...
Old 19th November 2006, 02:15 PM   #4
EUVL is offline EUVL  Europe
Ralph,
Short plus to minus. Check amp stability with shorted outputs with an oscilloscope (i.e. it does not oscillate).
And make sure the relay has sufficient current rating.
I use automotive relays.
Patrick
Old 19th November 2006, 06:21 PM   #5
harryeng is offline harryeng  Netherlands
Hi Ralph,
I am building an Aleph X myself, and am just starting on DC protection.
A problem is that most DC protection circuits are not differential, but measure DC against zero. The only one that claims different is Euvel. Check out his post:
http://www.diyaudio.com/forums/showt...018#post434018
When you short-circuit + against - you have no in-line contacts. One of the relays that can handle the DC load is: Amplimo . Check under Amplifier Modules, down at the bottom.
Please keep us "current" with your solution.
Greetings, Harry.
Old 19th November 2006, 07:02 PM   #6
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by harryeng
Hi Ralph,
A problem is that most DC protection circuits are not differential, but measure DC against zero. .......................
Greetings, Harry.
try uPC1237 for that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th November 2006, 04:40 AM   #7
Thanks for the informations - I will shorten + to -
I think about using a microcontroller and measure the voltage of both output against ground. Than I get the information about the differential DC offset over the load and the absolute offset of each output.
Ralph
Old 20th November 2006, 05:44 AM   #8
uPC1237 measures DC offset to ground, so not differential.
Of course you can change the input circuit, but as Harry pointed out, I have already published a full differential circuit. It works without a hitch for 4 years (not that I needed it at any time). It is much easier than a P, and I do not particularly like HF circuits near my analog amp. You need to adapt the circuit a bit for different relays (in terms of coil current).
If you want readout, 2 (or even 3) multimeters from Reichelt at 6 Euros each is the easiest solution.
And the quality of the relay contact for a shunt protection is not important. It just has to handle a hugh pulse current (say 200A min.). You can also short to a small power resistor (say 0.1 ohm 50W) to make life a bit easier for the relay.
Patrick
Old 23rd November 2006, 01:19 PM   #9
Zen Mod's Avatar
download pdf and you'll see (if I understand it correctly ) that 1237 don't need gnd for sense.
both legs for sensing (L and R in stereo connection ) are virtual ground .....L for R and vice verse;
perfect for diff use
Old 24th November 2006, 01:40 PM   #10
When Pin 2 is 0.7V above pin 5, pin 6 will go open, turning the relay off. In operation, Pin 6 goes to Gnd (=Pin5).
In the circuit published, the 56k resistors plus the 330F cap form a low pass filter to isolate the DC component of the amplifier output, which if more than 0.7V will trigger the protection circuit.
So let's take your suggestion and connect the +ve output of an Aleph-X to the Rch point in the circuit, and the -ve output to the Lch point. A 2-V common mode absolute DC will certainly trip the relay, but a symmetrical differential DC across the outputs will do nothing, as the 56ks form a pontential divider which gives you a nice 0V at the +ve pole of the 330F cap.
Or you have something else simple in mind which does not require a differential amp (opamp or otherwise) ?
Patrick
Short the Output of an Aleph XHide this!Advertise here!
Cyrus 2 no output after short fall WNR Solid State 9 24th December 2012 01:14 PM
Can OPA627 short output to ground? klitgt Digital Source 7 22nd February 2006 09:06 AM
Short circuit output protection scheme tool49 Solid State 6 14th November 2005 07:57 AM
speaker protection and output short patriz Chip Amps 3 10th January 2005 03:55 PM
Adcom GFA 555-II- Didn't like short on output :-( Magura Solid State 3 17th November 2004 02:17 AM
Copyright ©1999-2017 diyAudio
