I tend to give people the benefit of doubt, but you guys tell me if I was duped into buying a Toroid I thought was a 2kVA Part. It is pictured here in the middle next to 3 different 1 kVA toroids that I already own and know they are 1 kVA. The one on the left is a Plitron, the top one is Antek and the large one on the bottom is a Hammond. While I know "size aint everything".... I cannot get over the thought that this no name part cannot be 2kVA . (PS: I will not disclose the DIY member who sold it to me for he may come clean on his own...) Best, K-Dupee |
#2 |
To be fair, the supposed 2kVA part is slightly taller than the Plitron and the Hammond Toroid but about the same as the Antek...
As far as mass goes... Antek 1kVA : 15.0 lbs Plitron 1kVA : 15.5 lbs Hammond 1kva : 23.0 lbs 2kva "supposed" 14.5 lbs.... |
#3 |
K,
could be in good faith, half of the population here can't recognise their own dickcheney if it was electronic. I've got a couple of 1kW Plitrons, and find them pretty sizy compared to most other brands. Got some biggies in the 1.8 to 2kW range from other toroid manufacturers, some are not much bigger than the Plitrons overall but each one easily outweighs them. If your 2kWatter weighs less than the 1kW Canadian, you've been conned imo.
Not so much,.......if it says "ZM" in the corner. |
#4 |
Yeah,
Hammond transformers makes you vision chunky Canadian dames in lumber shirts that offer the option of armwrestling you under the table or the stretched embarassment of the same by outdrinking you. (i hate to see Ozzy toroids, and i stopped JB shots contests with women)
#5 | |
Even if weight is not everything ( wires matters, too ) when it comes to toroid transformers: Weight DOES NOT LIE lineup
lineup |
#6 |
Tell me about it, i'm at least a 16kVA Donut.
#7 |
Harbuch Antrim 2kVA toriods are 17kg. Unfortunately I don't know what lbs are anymore but they used to be a lot smaller than kg. http://ourworld.compuserve.com/homep...ch/harbuch.htm regards
Greg Erskine |
#8 | ||
1 lbs = 0.45 kg 1 kg = 2.2 lbs 17 kg should then be ~37 lbs ( compare to those 1 kVA ~15 lbs ) ------------------------------ edit: found a link about metrics, and With online conversion service http://www.curezone.com/conversions.asp Quote:
lineup |
#9 | |
I looked up several Toroid Transformer manufacturers data. Based on VA ratings / weight data we make up some rough formulas. I think most makers of transformers use a core material with almost the same quality. There are always exceptions, but for the major public main stream market, to affordable prices, I would say there are only small differences. Say max +-15 % in VA per core weight. ###################################### Here is my attempt to make such rule of the thumb formulas. The Toroid Transformer data I used comes in 15 - 4000 VA and looks like this: ![]() Approximate formulas. Quote:
A toroid weighs 1.9 kg. Set k=0.4 VA = 100(1.9-0.4) = 100x1.5 = 150 VA .................................................. ................................ Web Reference used: Shenzhen Okerda Science & Technology Co., Ltd is a manufacturer specializing in custom designed transformers, coils, and power supplies. OKERDA HEAD OFFICE (SHENZHEN) Shenzhen City, Guangdong Province 518110, P.R.China British Office: Mr. Hao Tel: 0044—2089856157, Cell phone: 07830113768 Address: 80B, Coopersale Road, Homerton, Hackney, London, UK E9 6BA http://www.okerda-tech.com/ .................................................. ................................... lineup Lineup Audio Lab Audio Mains Transformers Division
lineup |
#10 |
This is a 4KVA transformer I am using for my prototype 2kw GND Bridge amplifier.
There is no way that transformer is 2kva |
| Amp Turns on and off whats wrong?? | db junkie | Class D | 2 | 26th October 2005 12:09 PM |
| What's wrong with this picture? | EchoWars | Solid State | 2 | 8th June 2004 08:40 AM |
