Grey and/ or John Inlow,
I got the boards yesterday in the mail, thanks John. I do have a question. If I pull down the schematic Grey put out on 5/24/02, will the parts on the schem. match the board's screen? I tried to search for a parts list but found none under Aleph X. Thanks and Merry Christmas, Vince
#2 |
Merry Christmas, fella,
I never got around to posting a formal parts list...or at least I don't remember doing so. Probably should, I guess. Considering that I've got myself involved in the high-powered Aleph-X dingus, I'll have to dredge around and locate the schematic (the version I posted and the prototype had some differences...). If I can keep my focus, I'll get you up a shopping list. As to what the boards take, I dunno. You'll have to ask the board guys. I'm not sure what path they chose. Grey |
#3 |
Paper mache horn fabricator
There's a parts list on the alpha pcb thread that follows Grey's original specs (fairly certain). The latter schematics I posted (same thread) include Grey's follow ups and are not posted in the parts list. If you use the latter schematics you'll need to modify the parts list. The only changes are the two resistors that accompany V2.
John |
#4 |
here......
#5 |
You guys rule!
#6 |
the parts price would also be nice
#7 |
Bricolo
should we buy the parts for you, too?? A note on the part list: R19-29 should be 20 K max (per Nelson comment) I am using 10K. 68k is too much. the FDB res can even be 200K and resistor to GND 100 ohms. 5 or 10 pf in the feedback loop should work. The original IRFP044 should be better here. They have higher transconductance. IRFP140 should work as well. |
#8 |
would be nice
#9 |
Hi grataku,
What happens if you run 68k on R19/29? |
#10 |
What happens if you parallel a 100 ohm and a 1000 ohm resistors? You can get rid of the 1k ohm because it does almost nothing.
| Mini Aleph Board & Aleph 2 Parts List | gpsmithii | Pass Labs | 3 | 16th January 2010 03:58 AM |
| Volksamp Aleph 30 schematic and parts list needed | KevinLee | Pass Labs | 9 | 22nd December 2008 02:04 PM |
| ESP P-101 parts list | jeffshort2000 | Solid State | 2 | 27th August 2007 02:08 PM |
| wanted :100W Aleph X (kari's board) bom/parts list | dhole | Pass Labs | 32 | 19th March 2006 11:27 AM |
| Page generated in 0.09737 seconds (75.85% PHP - 24.15% MySQL) with 11 queries |
