Old 15th November 2006, 01:40 PM   #1
Default Zen ZV9 power supply
What is the best way to feed the Zen ZV9?? Has anyone a schematic or a PCB to suggest?? Please help me!!
Old 15th November 2006, 04:33 PM   #2
Alain Dupont's Avatar
Albertone,
look at the manual of similar Class A amplifiers, example Zen Amp
http://www.passdiy.com/pdf/zenamp.pdf
1 AC connector, a fuse, a transfo {3* times power used!}
choice of 1 or 2 secondaries {1 for each channel is better...}
100 watts for each channel, so: 250 to 300VA for each channel
that's a 300VA, for a monobloc or only 1 * 625VA for a stereo 2 channel
To get 50 volts DC : secondary(s) must provide: 36 volts AC on load to the bridge
And for each channel:
a bridge rectifier 25A/100volts
several capacitors, example 2*10 000microF
Perhaps a fuse for each channel DC, would be safe to protect the bridge(s) and transfo...
Alain.
Old 6th December 2006, 08:56 PM   #3
sts9fan is offline sts9fan  United States
Can someone tell me if this transformer will work for this project?
http://www.partsexpress.com/pe/showd...number=122-650
Also I am new at this and a bit confused on how to pick a transformer based on a schematic, If someone could lead me to some guidelines that would be sweet.
Kris
Old 6th December 2006, 09:16 PM   #4
VT67 is online now VT67  Belgium
VT67's Avatar
sts9fan
Alain summed it up quite nicely.
Yes that transformer will work with the secondaries wired in parallel. You will end up with a rail voltage somewhere between 46 and 49VDC. One of those per channel is also my advice.
Old 6th December 2006, 09:20 PM   #5
Kris,
Good choice, this will give you about 49 to 50 volts DC at 2 Amps for each secondary.
You will need 1 for each channel monobloc,
and you put the secondaries in // {parallel}.
regards.
Alain.
Old 7th December 2006, 02:13 PM   #6
Thanks for the help guys
I would assume that the AN 3236 would work also
http://www.toroid-transformer.com/
Old 7th December 2006, 02:30 PM   #7
VT67's Avatar
Yes. You could also use the AN 3218 with the secondaries wired in series.
Old 7th December 2006, 02:33 PM   #8
Is there somewhere I can read about the secondaries of these transformers? I am confused about the differnet configurations and why some would be wires in series and the other in parallel
Old 7th December 2006, 02:34 PM   #9
steenoe is offline steenoe  Denmark
steenoe's Avatar
I will second that, as an even better choice. It will give you more possibillity's later on. Most of the Passdiy amps can be made with 2x18V secondaries.
Steen
Old 7th December 2006, 02:39 PM   #10
steenoe's Avatar
Here is a nice place to start. Just go down the page untill you see the Transformer articles. All the other stuff is also worth reading.
http://sound.westhost.com/articles.htm
Steen
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.09523 seconds (80.28% PHP - 19.72% MySQL) with 10 queries
