Lady’s and Gents,
I have learned so many things from this forum and thanks to the generosity of its members (special thanks to nelson). The attached files will help those of you looking for an input selector board for your pass preamps. Its intention is to provide one balanced input and two single ended inputs the - inputs are shorted to Gnd during the use of the single ended inputs. One switch toggles between these three inputs, if input one is selected then one LED is lit, two are lit for input two and three for three. I have not built this yes so don't be surprised when I post the amendments I have etched the PCB but I am waiting for my relays to turn up prior to building it. |
#2 |
Hi Stones,
A couple of thoughts: I don't think the relay protection diodes are needed if you are driving with a ULN driver chip. Also you might want to consider a balanced Mute relay after you selection relays. -David |
#3 |
Thanks David,
If you want a mute then any spare input (or connected unit with no power) is mute and if you realy realy must have a selectable mute then remove the short from SJ1 and short SJ2 this gives mute as the forth selection. Regarding the protection diodes well it’s your choice if you bother to fit them or not. |
| Input selector | Simo88 | Everything Else | 25 | 15th July 2009 02:33 AM |
| input selector | lawbadman | Digital Source | 8 | 10th September 2005 10:45 AM |
| Input Selector | Semir | Solid State | 7 | 28th December 2004 07:18 AM |
| Input selector: need help | Cobra2 | Parts | 1 | 8th March 2003 08:31 AM |
| Page generated in 0.07664 seconds (68.15% PHP - 31.85% MySQL) with 11 queries |
