I have an Aleph 2 with 100k mfd capacitance in the power supply (in a CLC configuration). I have noticed that many people use much larger capacitance.
Am I missing out on something with having less capacitance? If I am over biasing, does this demand more capacitance as well? Thanks for any help you can provide. |
#2 |
Is that 100 thousand per amp (both rails), per rail, or for both channels? The amount of capacitance by itself doesn't supply enoungh information.
How much is enough depends on your point of view and on external factors like how noisy your power lines are. That said, 100,000 uF per channel sounds like a good number. Grey EDIT: Yes, more capacitance is appropriate for higher bias. |
#3 |
Yes, 100k per amp (both rails). The service manual states 4 x 22K. I am using a 1000 VA tranny.
I guess I was just wondering why so many people are using much more capacitance. |
#4 | |
Formerly "jh6you". R.I.P.
I think that they want the ripple voltage as low as possible. So, they try more capacitane than "good enough." I can hardly say that something wrong there . . . |
#5 |
Just ask Duncan's PSUD what's wrong with it.
Just paralleling capacitors at the rectifier's output makes things worse - charge current rises and generates nasty spikes you will hardly ever get rid of. Increasing capacitance behind the choke is another story. Do yourself a favor and play with PSUD, there's a lot to learn about such a (not so) simple thing like a power amplifier supply. |
#6 |
Thanks - I will do that. I have much to learn...
#7 |
Caps across the diodes will do quite nicely in taming spikes. You can also use soft recovery diodes. It's not that big a problem.
Grey |
#8 |
I am using the IXYS FRED br. Would these benefit from the coupling caps?
| =>$100k Amplifiers !!! | Bonsai | Solid State | 19 | 29th November 2008 03:39 PM |
| EL-34 and 100k pot | podboy | Tubes / Valves | 1 | 26th June 2007 11:49 PM |
| i need 100k log pots | brian marshall | Parts | 2 | 30th July 2004 04:23 PM |
| 50K vs 100K POT | ss1 | Parts | 7 | 22nd July 2004 12:57 PM |
| 50K or 100K pot? | 2Bak | Chip Amps | 14 | 9th November 2003 02:25 AM |
| Page generated in 0.08180 seconds (76.82% PHP - 23.18% MySQL) with 10 queries |
