More Power for ZEN - Page 2 - diyAudio
Old 14th October 2001, 10:27 PM   #11
There's no reason you have to build 4 discrete Zens. Just parallel the circuit from the start; build all four into one chassis, with one power supply, etc. No sense in making a rat's nest of cabling if you don't need to, as the Zen should parallel very easily. If nothing else, you'd save money on the DC blocking caps, as you'd only need one set per bank.
Grey
Old 14th October 2001, 11:07 PM   #12
promitheus's Avatar
Yeah of course you make everything in one box. Parallel everything in the inputs nd outputs. And you only need one capacitor in the output. I think when used balanced you donīt need the blocking caps at all.
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 07:38 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
Copyright Đ1999-2017 diyAudio
