Hi there!
I got some matched mosfets for my aleph p1.7, they are IRF630. Is the sound worse than IRF610. Is the IRF610 the only option, or could I use also the IRF630, without hearing more distortion? next to the IRF630 I got IRF9610, can they do the job together? Thanks allready for the answer. grtz Teake |
#2 |
Formerly "jh6you". R.I.P.
Just build it and listen to it.
If the sound is not to your satisfaction, replace them with whatever you think of . . . |
#3 |
Will an IRF630 work ? Sure !
But why no try to read a datasheet, an IRF630 is 4 times an IRF610 : 4 times more current. 4 times lower RDSon. 4 times higher power. 4 times higher capacitance. I've used IRF630s as power amp output devices. Do yourself a favour, buy IRF610s.
Not so much,.......if it says "ZM" in the corner. |
#4 |
The one and only
I have successfully used IRF230's in the P. The sound is
different, but generally acceptable. |
| FS IRF610 / IRF9610 mosfets | HIPCHECK | Swap Meet | 1 | 14th May 2008 07:31 AM |
| WTB: IRF610, IRF630, ZTX450 and ZTX550 | folkeb | Swap Meet | 0 | 1st July 2006 10:44 PM |
| Mosfets and BIAS - sound design... | Buhl | Pass Labs | 25 | 25th June 2005 06:06 PM |
| irf630's | odysseybmx414 | Solid State | 3 | 11th March 2005 11:23 AM |
| Replace IRF610 with IRF510 how about sound quality? | Nattakorn | Solid State | 5 | 22nd November 2001 05:00 AM |
