#291 |
Grataku,
Let's take this discussion in a new direction. Whether it be the Aleph 1.2, or the XA200, or a 200W Aleph-X. Would the 'gain' justify the 'pain'? Regards, Dan |
#292 | |
diyAudio Moderator Emeritus
You might think about a few more hours into January and February because for a 200w Aleph X your going to need 2 of those 1500VA Plitrons (one for each channel). Even that would be marginal if you wanted to make the Aleph1.2 mark of 300w into 4ohms. Here's Williams post which includes his spreadsheet for calculating power dissipation in the Aleph X http://www.diyaudio.com/forums/showt...066#post101066
Rodd Yamashita |
#293 |
I believe I have enough spare parts to complete the power supply and heatsinks for a single 'test' channel. If I could talk a couple people local to me like Peter and Coulomb into some sort of joint effort I think we would have some interesting pics by March.
How's that for a little optimistic stab at the outer limits? Regards, Dan |
#294 |
Well the 1500VA Plitron is $191 CAD, I have two at 60 VAC for my Aelphs. I guess I will need two more at 22 VAC secondaries and 8 Amps of bias to get 160 watts into 8 ohms. The thing is my speakers are 6 ohm loads, which will give me 225 watts TOP.
I think I will just leave them outside this winter, that should keep the snow back 20 or 30 feet from the house! Anthony |
#295 | |
Just don't stick then under the thermostat, it might get a little chilly in your house.
Rodd Yamashita |
#296 |
#297 |
Oh yeah,
Now I remember those cases from the first time you linked to them a while back. They should do the job quite well.
Rodd Yamashita |
#298 |
Coulomb,
Where did you source those heatsinks? Regards, Dan |
#299 |
eBay, $8 US each. I bought 16 of them.
eBay rules for sourcing Heatsinks and Capacitors. Anthony |
#300 | |
The cases are not finished, I have to do something with the corners. There will be a Hardwood trim on the bottom on the front and sides with the I/O on the lower back. Right now I have Dales boards set up to give me two FETs per heatsink - 16 in total. With the spreadsheet I grabbed from this forum it looks like I want 8 Amps at 27 VDC rails. Regards Anthony |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| Industrial AlephX High Power version | Netlist | Pass Labs | 151 | 1st July 2009 07:51 PM |
| AlephX High Power version circuit needed | space2000 | Pass Labs | 3 | 13th June 2008 12:50 AM |
| Page generated in 0.10710 seconds (81.69% PHP - 18.31% MySQL) with 11 queries |
