#271 |
mmmm,
well the first version was allright. I´m not responsible for all the later versions of berekening but if I remember right the v2 and 3 were basically the same with some usefull extensions. Another thing I see in the one on the right hand side is the dissipation wich is only half (170 watts instead of 340 watts, 6,8Ax50V x 2) william
een ooievaar is geen konijn want zijn oren zijn te klein! |
#272 |
diyAudio Moderator Emeritus
Look what they done to my song, ma The only thing I could do half right and now it's turning out all wrong, ma Look what they done to my song
Rodd Yamashita |
#273 |
thank you Rodd!
It´s so nice when someone feels sorry for me. william
#274 |
Grataku, where would one find these PCB's for a 200 Watt Aelph X?
Anthony |
#275 |
How might one get such boards?
Anthony |
#276 | |
never From the figure and the heat will be the deciding
#277 | ||
See here where Edwin Dorre made a 130wpc AX with 16 output devices per channel. As you can see, he used P-t-P to wire the 4 banks of 4 devices. http://passdiy.com/gallery/alephx-p3.htm 200wpc will need 4 banks of 6 devices (depending on the per device power disipation). You could use Dale's (Harvardian) output boards, if there are any around. http://www.diyaudio.com/forums/showt...4019#post64019
Rodd Yamashita |
#278 | |
http://www.heater-home.com/heaters/e...ark-3ug62.html Without the fan. Knowing that hot air rises, you could duct the heat to the outside.
Rodd Yamashita |
#279 |
amo,
six channels 0f 40 watts will give around 6x40x2.5= 600 watts of heat. The faktor 2.5 stands for around 40% efficiency wich is probably a bit too high. william
#280 |
Roddyama I have 24 of Dales output boards and still have 10 of the FEB as well, yes I have built 2 Aelphs with them so far. So with Chad's boards I would parallel Dales boards off of the outputs?
Anthony |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| Industrial AlephX High Power version | Netlist | Pass Labs | 151 | 1st July 2009 07:51 PM |
| AlephX High Power version circuit needed | space2000 | Pass Labs | 3 | 13th June 2008 12:50 AM |
| Page generated in 0.11001 seconds (82.27% PHP - 17.73% MySQL) with 11 queries |
