#91 | ||
Blitz
I like a choke too when I can be assured the aforementioned problems are not issues but until then, I will enjoy them much more in other peoples amps than my own. |
#92 |
Inductors are fine. There's no need to be suspicious of inductors in power supplies. The reason you don't see them in more pieces of commercial equipment is because they're comparatively expensive and bulky. For the average DIY critter those aren't big concerns--especially if you wind your own.
I'd use them more often, but I'm hampered by inability to get decent gauge wire here in SC. Would you believe that the biggest wire I can find in the entire blasted state is 14 ga.? And they act like that's asking for the moon. They'd rather talk about 16 ga. and smaller. I draw the line at mining my own ore, smelting the copper...there's a practical limit to this DIY thing. <i>Sigh</i> Grey |
#93 |
The one and only
I gave up making my own transistors in the 12th grade.
#94 | |
diyAudio Moderator Emeritus
-- Brian |
#95 | |
BrianGT
#96 |
I actually considered the possibility of making my own tubes at one point. I've got several old McGraw-Hill textbooks on the nitty-gritty involved, but decided it would be a little-bitty smidgen too far along the diminishing returns curve for me to justify the trouble.
All the wire I've seen at Lowe's/Home Depot is standard house wiring stuff with a plastic jacket. Do they have enamel insulation stuff hidden away somewhere? I ought to come over and visit. The Atlanta area alone has a more extensive industrial base than the entire state of South Carolina. I could probably pick up all sorts of things over there. Grey |
#98 | |
Good luck forming a coil out of it, though.
#99 |
Sparhawk
Do you know if these wire gauge measures are a recognized ISO (or any other organization) standard? The notion that a wire can be custom made for any application was not unfathomable but I was surprised to learn that "0 gauge" is common enough to put on a wire measuring gauge and even more surprised that a Home Depot would carry it! Your comment about winding a coil with it corroborates my point about how practical it would be to use it. BTW, I have seen a transformer built with "gauge 1" wire and know the man who wound it (my uncle). It was 12"x12"x26" and weighed 320lbs and he was the one who showed me that aforementioned apple trick. |
#100 |
Nania,
These are American Wire Gauge (AWG) sizes. There are other standards, such as the British SWG (Standard Wire Gauge). Metric sizes are in square millimeters. I don't know if there is an ISO standard. These sizes are quite common in commercial / industrial applications. Our data centre here has a 600/208V step-down transformer with 2 parallel runs of 500kcmil on the secondary. (For comparison, 1 ga. wire is about 83kcmil). |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 12:11 PM |
| Industrial AlephX High Power version | Netlist | Pass Labs | 151 | 1st July 2009 08:51 PM |
| AlephX High Power version circuit needed | space2000 | Pass Labs | 3 | 13th June 2008 01:50 AM |
| Page generated in 0.12033 seconds (79.66% PHP - 20.34% MySQL) with 11 queries |
