If you eliminate C11 and C12, you'll skew the RIAA EQ. Setting that aside, you could offset Q6 above ground by the 15V volts or so that it would take to put it at the same potential as the collector of Q5. The best way to do it would be a separate power supply, lifting 'ground' and the rail both. There's a DC blocking cap at the output, so DC offset at the signal output wouldn't be a problem.
Grey
Grey
GRollins said:If you eliminate C11 and C12, you'll skew the RIAA EQ. Setting that aside, you could offset Q6 above ground by the 15V volts or so that it would take to put it at the same potential as the collector of Q5. The best way to do it would be a separate power supply, lifting 'ground' and the rail both. There's a DC blocking cap at the output, so DC offset at the signal output wouldn't be a problem.
Grey
Yes I can recalculate RIAA.
Floating is the only way......
THANX
