Would this work
Would this work
Old 21st December 2002, 08:43 AM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Default Would this work
OK, I give up, I just dissasambled my entire PCB, for the balanced line stage, planning to make a complete new design, unbalanced only.
I have found this schematics (Thank's to the author),
Would this work ???? ( The one I had redrawn ? )
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 21st December 2002, 08:45 AM   #2
lykkedk's Avatar
Default Re: Would this work
And the Schematics I had found is this :
Old 21st December 2002, 09:00 AM   #3
lykkedk's Avatar
Default Re: Re: Would this work
And connected like this to RCA :
Old 21st December 2002, 09:07 AM   #4
2Bak is offline 2Bak  Denmark
this will work fine
Old 21st December 2002, 09:14 AM   #5
lykkedk's Avatar
Originally posted by 2Bak
this will work fine
OK THANX
Old 21st December 2002, 09:22 AM   #6
analog_sa is online now analog_sa  Europe
analog_sa's Avatar
This will work but you'll get better results if you retain the gate stopper and connect to ground through a similar resistance as the i/p mosfet. Differential amps achieve best CMRR when both inputs are driven by equal impedances. Also may be a good idea to retain the trimpot.
cheers
peter
Old 21st December 2002, 09:33 AM   #7
lykkedk's Avatar
Thanks, but could you perhaps draw that in on my schematics, cause I don't understand all of this !!!
Old 21st December 2002, 10:13 AM   #8
ElectroNick is offline ElectroNick  Netherlands
ElectroNick's Avatar
Would this work
Only a few more modifications and you would have a Bride of Zen ?
Why all that trouble, i would go for a BOZ right away if only unbalanced is needed.
Gr,
Nick
Old 21st December 2002, 10:25 AM   #9
lykkedk's Avatar
Gr,
Nick
Cause I think, the balanced, is better as unbalanced, than the BOZ
Old 21st December 2002, 10:51 AM   #10
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Referring to the schematic in the first posting, seeing the Q2 drain signal is just an inverted but equal amlitude version of Q1 drain signal, it doesn't appear that Q2 is really doing anything besides making the schematic look pretty. You could probably just take the signal from Q1 drain and throw Q2 and it's extra pieces away! The total source resistance may need to be altered because there is now only half the current in it.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Would this workHide this!Advertise here!
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 02:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 03:40 PM
Copyright ©1999-2017 diyAudio
