Old 23rd October 2006, 04:26 PM   #1
Default Aleph 2 turn-on thump
I am going active with my system and will be using my Aleph 2s for the Mid/tweeter section.
The concern I have is that the turn-on thump may cause my ATC mid some harm. Mr. Pass states that the Alephs have a volt or so that causes it (see link).
Nelson Pass comment re: turn-on thump
I also know that a cap on the reference zener can cause more of a thump which I do have on my boards.
My question is: Is there a simple solution to protect my mid or am I worrying too much?
Thanks for any help you can provide.
~Scott
Old 23rd October 2006, 09:44 PM   #2
For a midrange unit, I wouldn't worry too much.
(Tweeters are another matter.)
If it's a problem, put a fairly large value cap in series with the driver; something large enough that the cutoff will be several octaves below the nominal range of the mid. If you're still worried, you can fuse the driver.
I use modified Aleph 2s to drive my midranges (Bohlender-Graebner RD-75s). I run them straight in.
Grey
Old 23rd October 2006, 11:18 PM   #3
Thanks for the reply Grey.
I think I will use a large (~100uf) cap just to be safe. Easier than messing with my amp.
turn off thump jayme Tubes / Valves 6 23rd September 2007 07:40 PM
Leach Amp turn on thump? wigginjs Solid State 5 1st March 2006 01:32 AM
Aleph 5 turn-on thump - only the brave should read amplitone Pass Labs 4 14th January 2003 09:51 AM
Zen amp turn-on thump robertpear Pass Labs 5 5th January 2001 12:23 AM
Zen amp turn-on thump. vdi_nenna Pass Labs 2 22nd October 2000 07:27 PM
Page generated in 0.06903 seconds (70.43% PHP - 29.57% MySQL) with 10 queries
