BoZoS unbalanced again.
Old 20th December 2002, 11:40 AM   #1
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Default BoZoS unbalanced again.
Hi again, I wrote this new thread, cause I think someone might have misunderstod my quistion.
I'am just building this Balanced Line Stage, which I plan to use, for preamplifieng, lines from my CD, Computer, DVD etc...
None of theese, seem to be balanced equipment.
My CD is a SONY X55ES, which I will connect through GoldPHONO'S (RCA), the output will be golded too. The rest of the input RCA's will be cheaper one's.
The output should go to my Leach-amp which I think have an inputimpedance around 20kohm. The Leach amp is with one powersupply, and two mono-block's, with one RCA for LEFT input, and one RCA for RIGHT input.
I made a little change to the PCB for the line stage, so I could use 1,5k/11w ohm resistor instead of the two 750ohm/3w one's
Actually I have used a lot of time making the PCB (Handmade), and I allready soldert most of the component's to it, hoping to use it unbalanced without making any changes on the PCB, and component's used.
I was planing to use a stereopot for P3/P4, for volume control.
This is, what I really wanna know, so please HELP...
Howto use it unbalanced, maybe with some grounding at -IN, and -out, really i do not know howto do this...
What about R15, I use 124ohm. is this right, when not using P1, and P2.
Well I had not yet bought any pot's, so I am open to any suggestion's.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 20th December 2002, 01:06 PM   #2
Henrik is offline Henrik  Denmark
lykkedk
You simply short -In to ground with wire.
I wouldnīt short the unused output to ground, no need for that.
R15= 124 Ohm is ok!
Lower the gain as much as possible by increasing P5, this way You get the lowest distortion.
Henrik
Old 20th December 2002, 01:24 PM   #3
lykkedk's Avatar
[Then I only have to short -IN, and use GND / +OUT, to the female RCA (Phono) ?
What about C1 R9 R11, I dont have to use at all ?? , or could I just leaveout C1, cause I allready soldert the R9 and R11, into the PCB. The reason I ask about leaveout C1 is, that they're pretty big. (Would leave me more space for only one of them) javascript:smilie('')
I wasent thinking, of using P5, I just want to make a short here, that's why I quistion about
R15, because I have seen some schematics, where 430ohms where used in unbalanced operation.
Old 20th December 2002, 01:41 PM   #4
Yes.
Those You donīt need, unless You some day wants balanced operation.
Try some diffrent values, I think You will need about 350 Ohm for R15, but that depends.
Henrik
Old 20th December 2002, 07:38 PM   #5
2Bak is offline 2Bak  Denmark
If running unbalanced only you will not need a pot at P3 but at P4 only (e.i. a stereo-pot for both channels). However if you plan to use - out later (balanced out), then think twice before you buy the pot for P3, cause a stereopot cannot be used as pot for both P3 and P4. Only a 4-channel pot or attenuator can be used for that (balanced).
Old 21st December 2002, 07:54 AM   #6
lykkedk's Avatar
Yes sure, P4 only
BoZoS unbalanced again.Hide this!Advertise here!
Unbalanced bosoz m60gpmg Solid State 4 14th June 2008 12:31 PM
About output pot. value and gain on BoZoS.. Buhl Pass Labs 3 12th June 2006 10:01 PM
going from XLR to unbalanced, is this ok? Jean Solid State 1 14th March 2003 07:23 PM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
unbalanced janey Pass Labs 1 22nd December 2001 11:44 PM
Copyright ©1999-2017 diyAudio
