hi:
I am new here. so if I ask something stupid, please forgive me. I want to build a PASS balance zen line stage preamp. and wondering how do I do it with unbalance input and unbalance output? let's say that my amp will have one input and one output, so how do I construct it in a way that the input and output can support both balance and unbalance? thanks a lot for any kind of help. additional question, what do you think will be the match pass lab diy power amp for this preamp? |
#2 |
ancient approach from Pro world:
make it balanced input and balanced output make balanced volumes and balanced selectors use XLRs for both input and output case connectors then-if you use balanced source (or load) connect it balanced accordingly -if you use unbal source (or load ) just tie minus and ground on CABLE xlr plug.....
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
this will work too, but my objective is to have both unbalanced and balanced input/output for the preamp that I am going to DIY. for example, I want my pre-out to have both XLR and RCA connectors. Is there any possible ways to do that?
#4 |
Read Neson's BOSOZ construction guide on www.passdiy.com. THe BOSOZ manual is here: http://www.passdiy.com/pdf/balzenpre.pdf
I've built this BOSOZ as stated in the manual with both balanced and unbalanced in and out. My source selector has balanced in for 1 input and 3 unbalanced inputs. Good luck, -David |
#5 |
Dear HC167,
The attached may be what you want ? Thomas |
#6 |
dw8083:
sorry but I was not able to find anything about balanced and unbalanced input/output physical connection information. This is what I can found so far from the file. So is this the anticipated Bride of the Son of Zen? I suppose it is. It has an identical topology and is perfectly suited for driving the Son of Zen, but there is much utility to this circuit. It also serves as a nice balancedin to unbalanced-out or unbalanced-in to balanced-out converter. and also the following. The circuit amplifies a differential input to a differential output. Given a single input, it will amplify it into a balanced differential output, and is useful to convert unbalanced signal to balanced, either because you wish balanced operation or because you wish to convert a conventional stereo amplifier into mono bridged operation. Of course the circuit is happy accepting a balanced input, and besides using it as simply a balanced gain stage, you can choose to view either output polarity as a single-ended output of each phase. Thus the circuit also functions as a general balanced and unbalanced converter. But I do not understand how do I construct it in a way to support both balanced and unbalanced. sorry that I was being stupid
#7 |
thomasfw:
your diagram made sense. and is definitly something that I can consider. but, what if I want both balanced and unbalanced preamp output? With this design, is that mean I have to have a switch (or selector) to control the output signal go to my RCA jack or the XLR plug? I just want to have a design that made sense. sorry if I ask stupid question again. |
#8 |
you really didn't understand what I wrote or what?
if you use strictly balanced topology with connectors on case,volumes and selectors,then for bal-unbal switching you just use xlrs (cannons) on cable ends......... what ever you (or anybody else) do-can't be simpler and tidier; in any case-you can have both style of connectors in parallel ;switching to unbal is easy-just put shorts in appropriate XLR or put switches for that purpose (instead shorts)
#9 |
Zen Mod :
from the wiring connection point of view. I understand what you said. however, in the document (http://www.passdiy.com/pdf/balzenpre.pdf) of balance zen line stage, it mentioned that "It also serves as a nice balanced in to unbalanced-out or unbalanced-in to balanced-out converter." I am just wondering if I want to take advantage of this part of circuit, how am I suppose to do that, the document did not mentioned anything like that. I just want to take the advantage of the original design. |
#10 | |
OK regarding wondering----- easy-just ground minus leg of input (or output -depending what you need)
| Line output as line input transformer? | bambadoo | Tubes / Valves | 7 | 22nd January 2008 06:44 AM |
| Balanced line stage- input or output attenuator | nobody special | Pass Labs | 4 | 7th April 2006 01:18 PM |
| input switching design for balanced line stage | ijomojo | Pass Labs | 3 | 23rd January 2005 02:02 PM |
| Battery powered Balance Line Stage | icceman | Pass Labs | 10 | 26th December 2003 01:35 AM |
| Has anyone tried a low input capacitance MOSFET in a line stage preamp | MIKET | Pass Labs | 2 | 27th August 2003 08:29 PM |
| Page generated in 0.13218 seconds (78.22% PHP - 21.78% MySQL) with 11 queries |
