Old 20th December 2002, 11:23 AM   #1
Default Aleph 5 DC offset and bias adjustment
Sorry if this has been covered elsewhere but I did try and I couldn't find it.
I'm just finishing assembly of my Aleph 5 clone monoblocks and all appears to work fine on the bench.
Two questions, what level of DC offset is typical or acceptable on the output and ho can I adjust it if it's wrong?
Secondly I have read Nelson saying that Aleph 5's work better with higher bias curent. Assuming I have the thermal capacity in the sinks how can I adjust the bias up?
Bertie
Old 20th December 2002, 12:12 PM   #2
rwagter's Avatar
Did you really search. I asked because it has been covered really recently. B ut here are the links:
Aleph5....it works!!!
DC offset / Bias setting for Aleph 2
Upping the bias on Aleph 2
RALPH
Old 20th December 2002, 03:47 PM   #3
The one and only
Nelson Pass's Avatar
To answer the questions anyway,
about 50 mv is my standard for DC offset in Alephs. If
you need to trim it you can do so in a number of places,
but adjust the the Source resistance in the current source
which biases the differential input transistors is a good
place.
Yes, you can increase the bias easily enough using the
resistor which feeds the Base of the NPN transistor on the
positive current source. I forget the number, but its the one
which goes from the Base to a capacitor which is charged
by a resistor to the positive supply.
Simply removing this will up the bias without any other
alterations needed.
Old 22nd December 2002, 02:49 PM   #4
Yes I did search,
and thanks very much to Nelson for the reply.
Bertie
Marantz 4270 DC offset and bias adjustment The Donk! Solid State 6 8th February 2010 03:53 PM
Accuphase E204 DC offset / bias current adjustment slam Solid State 2 25th February 2009 04:39 PM
Aleph-x bias adjustment bach2800 Pass Labs 31 30th October 2006 10:03 PM
EE-Zee & Chee-Zee bias and offset adjustment idea thoriated Tubes / Valves 0 2nd April 2004 11:16 PM
DC offset / Bias setting for Aleph 2 fcel Pass Labs 24 26th August 2002 05:29 AM
Page generated in 0.08611 seconds (75.76% PHP - 24.24% MySQL) with 10 queries
