Old 20th December 2002, 06:34 AM   #1
PsykoK is offline PsykoK  France
Send a message via ICQ to PsykoK Send a message via AIM to PsykoK
Question BOSOZ, PS voltage problem or not?
I finish my PS board yesterday evening and in this can I run some test to check it.
I use only one transformer with 2*55 at secondary.
I check my Ac voltage and I have 2*61.8v
The drain of Q101 is a little over+80v and for Q102 a little under -80v.
The PS work fine but I get only : 59.1v and -58.7v with a 15K resistor charge. Without charge , I get +59.8v and -59.3v.
Are these volt values right or did I have any bug in my PS?
Thanks,
Alex
Old 20th December 2002, 07:05 AM   #2
ralf is offline ralf  Germany
Default Re: BOSOZ, PS voltage problem or not?
Thanks,
Alex
PsykoK,
i think (hope) it`s o.k.
in my Xsoz and Bosoz- psu`s the rails are not exactly the same. i think the reason is the light difference in parts.
But there are psu`s with which you can regulate the + and- rails with a pot, but not necessary on bsoz.
What do others think?
Ralf
Old 20th December 2002, 07:54 AM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
Seems to me that you just built a perfectly working PSU for a BoSoZ...
If you feel like it you can probably swap around some Zeners until you get the same voltage from both rails. That would not be necessary though as everything is fine as it.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 20th December 2002, 08:12 AM   #4
Thanks for your help!
BOSOZ Problem vdi_nenna Pass Labs 52 10th March 2008 06:50 PM
BOSOZ Hum Problem hifileslie Pass Labs 12 18th September 2007 04:28 PM
BOSOZ PSU voltage question cowanrg Pass Labs 9 25th September 2005 07:28 PM
BOSOZ rail voltage pro Pass Labs 6 20th July 2004 07:21 PM
BOSOZ PSU problem tcl2 Pass Labs 7 5th July 2004 03:08 PM
Page generated in 0.07467 seconds (74.22% PHP - 25.78% MySQL) with 10 queries
