Aleph P 1.7: 2k pot is in the signal path?
Old 19th December 2002, 07:17 AM   #1
swede is offline swede  Switzerland
swede's Avatar
Default Aleph P 1.7: 2k pot is in the signal path?
Hello!
I've had some thoughts on the 2k pot between R51 and R66 on the Aleph P 1.7 pre amp board. (see http://www.passlabs.com/pdf/aleph/apserv17.pdf)
Is it to be considered to be in the signal path, hence call for an expensive pot, or could I just go on and use any regular "found it on the street" pot?
Best,
//magnus
Old 19th December 2002, 03:28 PM   #2
Ignatz is offline Ignatz
I do not use a pot as a gain resistor.
Actually I replaced R51 and R66 with a 2K2 single resistor.
I get plenty of gain from all my sources, becuase I have modified the input resisitor values for each source. The input resistors are before my selector switch and are sized for each different source to give good volume at about 90% of my attenuator setting.
I maximized the gain resistor, because I assummed like the BZLS the distorion would be the least with the largest resistor value.
I think there is also a reference in the P 1.7 manual about trying to maximize the gain setting for best performance.
I am very pleased with the resulting sound quality.
Old 19th December 2002, 03:52 PM   #3
swede's Avatar
Default Thanks!
Thanks for your info. It is really helpful! I think I'll do the same as you do!
Though, I didn't get an answer to wether the pot is in the signal path or not. ;=) Is it?
//magnus
Old 19th December 2002, 05:32 PM   #4
Default pot in signal path
I think the pot might be thought of as in the signal path because any fluctuation or noise from the source of Q16 will affect the gain of Q19 and vice versa.
Therefore anything connecting the two sources has an affect on the signal.
Maybe the fact that a larger value gain resistor creates less distortion is because it increases the slight isolation from Q19 to Q16. (This is my guess).
Old 19th December 2002, 09:55 PM   #5
GRollins is offline GRollins  United States
Look at it this way:
Assume a single-ended input. Drive the left half of the circuit. An output appears at the right side by virtue of having entered through the Source of that MOSFET via the 2k pot.
<i>Ta da!</i>
Yes, it's in the signal path.
Grey
Old 19th December 2002, 10:00 PM   #6
swede's Avatar
Default In the signal path...
Hence, it is evil. ;=)
//magnus
Old 19th December 2002, 10:06 PM   #7
swede's Avatar
By the way!
GRollins: Welcome back! I've missed you!
//magnus
Old 19th December 2002, 11:25 PM   #8
Evil?
Well...
So are gain devices, if you choose to look at them in terms of the harm they do to the music.
Sooner or later, you're going to need to use a volume device of some kind, whether a pot, rotary switch & resistors, fancy transistor (or chip) array, or whatever. It will either be directly in the signal path, change the operating point of the gain device(s), or change the amount of feedback. Any way you slice it, you're going to have to shake hands with the devil at some point...might as well make up your mind to enjoy the experience.
Go ahead and put it 'in the signal path' (as though there were any other way...) and be done with it.
Grey
Old 28th December 2002, 09:12 PM   #9
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Aleph P 1.7: 2k pot is in the signal path? Aleph P 1.7: 2k pot is in the signal path?
Default Aleph P 1.7 pre amp Q:
While discussing the "gain" pots...
Why not use (re-construct) these as volume pot? (when not in need of balance).
What I have heard, in a balanced circuit, it is much better to "cancel out" sound between +/- phase w. even a cheap pot-meter, than having the best pot. in the signal-way.
(Ref.: Electrocompaniet).
Other thaughts?
Arne K
NORWAY
Old 29th December 2002, 12:10 AM   #10
macka is offline macka
macka's Avatar
HI Grey,
Nice to see you back,
I see the function of R15 in the BOSOZ to be basically the same as the 2K pot in the P1.7
I thought about this and found it easier to use R15 = 450R and parellel with a 2K Pot in series with say 150 - 200 R.
This would appear to make the use of the pot legitimate while keeping the Dale fixed resister in the signal path so it is only shunted by the pot when in use(for higher gain). Hence the effect of the pot on quality is minimised.
This is a bit off topic but I would like your clarification here Grey.
It seems in the Aleph P.17 Preamp the manipulation of the output levels is a bit misunderstood relative to the BOSOZ.
There is no input volume control in the P1.7 , only an internal pad for some 12 db attentuation so to set and forget, the Gain level controls (2Kpots) and and the Master Volume control at the output (a shunt attenuator).
I trying to figure out if the BOSOZ can be set up the same way as the P.17, or does the circuit perform differently in respect the the active use for R15 and of P1 & P2 level controls at the input and its optimum operating point.
In the Pass manual for the P.17 it states for best performance keep the gain level controls counter clock wide (minumum gain) and the Master Volume control as clock wise as possible.
This to me means keep the gain low and it is preferred for best performance not to have the output shunted down too much to enable reasonable voltage swing.
Could this perhaps suggest why there is a tendancy for everyone to use a 5K pot or (or series switched attenuator) rather than the shunt attenuator for the BOZSOZ so the output impediance is constant?
best regards
Ian
Aleph P 1.7: 2k pot is in the signal path?Hide this!Advertise here!
Panasonic FM on signal path ? deuginthesky Digital Source 5 22nd July 2008 09:31 PM
How does this sound for a signal path? Fryguy Digital Source 0 25th May 2004 08:15 PM
Help identifying the signal path Eric Solid State 7 24th August 2001 08:10 AM
Copyright ©1999-2017 diyAudio
