I made these boards with Staple brand Basic Inkjet Photo Paper.
I read about it on the net. http://www.fullnet.com/u/tomg/gooteepc.htm The board trace is imprinter on the inkjet paper with a laser printer. A inkjet printer can't be used. Pic od transer with paper removed: |
#2 |
Hey Vince,
what about the black spots ?
Looks like Sponge Bob has killed another thread. |
#3 |
Pic of board after etching bath; before cleaning:
#4 |
Jacco, your fast!
#5 |
Nice Ha, with like 3000 miles between us.
![]() Better hurry with the Zen9, winter's coming. Even magnified your pics, the traces look really good, seems like a good trick.
#6 |
Board after rough cleaning:
#7 | |
It's better than the Tech2000 transfer film. I used the Tech2000. This cost 1/2 of the cost of the Tec2000 and looks better. 30 sheets of the Staple Basic Photo paper cost me $9. It was on sale from $15. One thing I should have done was keep the iron on longer. When the paper starts to brown and the edges stick the copper, you're almost there. It's tough to get the paper off once it's on, but the transfer is strong. It won't come off from scrubbing. |
#8 |
I also used this procedure.
I used matt paper, 90g (very light), 8,30 Euro for 100 sheets... I've made several experiments and the procedure is - almost - near to the perfection. Tricks: pre-heating: a thick paper between the iron and the copper seems to prevent non-homogeneus heating. heating: pressure is as important as iron temperature is. pealing-off: use some tensio-active (i.e. standard detergent, I use one for floor washing): you will see the paper to become transparent, and very easy to remove. Your thumbs and a toothbrush will do the rest of the work. With a permanent marker, correct the eventual holes (take care: the ink seems to dislike the edges, two pass is better than one). Etching: try with Muriatic Acid and Hydrogen Peroxide, it's very fast (but use a mask and glasses, and protective gloves). Try this procedure, it's really easier and useful than you can imagine (but don't mind Veteran, your boards are of another planet...) |
#9 | |
Vince |
#10 |
Vince,
Looks really good. Now you need to find a source for super tiny drill bits. That was the tricky part for me. I've made quite a few boards using the "Press-n-peel" blue stuff. The only thing I would comment is that it looks like you etched away quite a bit of material which "consumes" your etching solution. Next time you may consider keeping that material there, attaching it to your ground plane and only etching away a small (maybe 1/16" - 1/8") seperation around the individual traces. This way you use a lot less of your etching solution. The etching solution becomes less effective with use as the acid molecules are consumed eating away the copper. -- Danny |
| L/R Boards and Matched IRFP240 Boards for Aleph/ A-X | lgreen | Swap Meet | 7 | 25th August 2009 04:56 AM |
| FS: Conrad Heatsinks;.... 'PASS' B1 boards w/JFETS;...... F4 AMP & PSU boards | cowboy99 | Swap Meet | 5 | 25th August 2009 02:39 AM |
| Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips | analog_sa | Swap Meet | 4 | 14th March 2009 05:29 PM |
| FT: Pass boards for P101 boards | bjefferys | Swap Meet | 1 | 26th March 2006 07:39 PM |
| amorphous paper or Mu-metal paper can use for D/A chips for shielding or not???? | siu sin man tho | Digital Source | 0 | 17th March 2004 12:31 PM |
| Page generated in 0.10994 seconds (79.19% PHP - 20.81% MySQL) with 11 queries |
