To NP the one and only!
Old 3rd October 2006, 04:20 AM   #1
johndiy is offline johndiy  Greece
Banned
Default To NP the one and only!
Dear Nelson
Goodevening
i have built a zen which i use it for headphone listening
it is powered by mains ps, ripple is low but for headphone
listening is unacceptable
what do you suggest i do to ps to keep the hum low
should i use regulation (discrete or ic?) or use passive
filter smoothing
can you post a good ps circuit i could use
thank you Nelson
john
ps if anybody can suggest solution to my problem please do
Old 3rd October 2006, 04:50 AM   #2
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, John,
-LC
-RLC
-Cap Multiplier
I don't know why, but I like the one that don't have semiconductor in it
Old 3rd October 2006, 04:54 AM   #3
Banned
Hi David
thanks thats very nice of you
well
can you design for me a ps circuit and post it
here so i can try it out
thanks again youre a champion
john
Old 3rd October 2006, 10:12 AM   #4
lumanauw's Avatar
Hi, John,
There are alot-lot-lot of examples of what you need here. A little search will help to find it.
From NP (in various amps/articles), from the Zen series of articles, from Choky examples, from Blowtorch thread (intended for small currents, but use the principle), and many more. They are all better than what I can draw .
Old 3rd October 2006, 01:39 PM   #5
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
if you look under legacy projects on the passdiy website - the
Zen Revisited article discusses a PSU update. Going CLC really
quieted down my Zen amp.
And then of course there's this legendary thread:
Tortello's Zen-like headphone amp
Old 3rd October 2006, 05:14 PM   #6
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Did you use the artwork posted in Audio Amateur? If so,
there is a layout issue which contributes some noise and
is easily fixed.
Old 5th October 2006, 04:44 AM   #7
Banned
Nelson Pass:
is easily fixed.
Hi Nelson
the amp is similar to zen but not zen
you are truly spot on with layout issues though,
hum is induced at the input and this has been
the cause of the problem
after doing some tests, i have managed to isolate
the layout problem and come up with a partial
cure i am satisfied with ,there is still slight hum
but this is in line with some sony amps i have
tested
actually i thought i needed to improve the ps but
after doing some tests it was found to be rock
solid ,then i turned my attention to what youve
pointed out and bingo!
i want to thank you nelson for taking time to
answear and help me solve this problem you are
truly amazing,,, nelson nelson nelson!!!,,, no1!!,,,
kind regards
john
ps: i am a student so thanks for your help guys!!
Old 5th October 2006, 06:23 AM   #8
TJ is offline TJ
hi , i got one crazy idea about the inductor . Can i use the inductor from the speaker x- over put into my aleph amplifier power supply ? some sub woofer inductor are very big and high inductance .
Old 5th October 2006, 06:41 AM   #9
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Depends on the type of coil and rating, TJ.
The aircoils used for CLC arrangements can be/are also used for loudspeaker filters. Some DIY loudspeaker kit shops sell the kind of coils which are generally used to make a CLC, i bought a number of really big ones during a sell-out by one of those shops overhere.
The majority of coils in filters are types with cores, they can not handle the high DC load in CLCs and will saturate.
Afaik, only two here have had satisfactory results with a core type coil in a CLC, a Torobar coil with a 600 watt rating.
That has to be a very impressive subwoofer if it has a filter with a suitable coil to use in a CLC.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 5th October 2006, 11:20 AM   #10
Babowana is offline Babowana  South Korea
Formerly "jh6you". R.I.P.
Babowana's Avatar
Originally posted by johndiy
. . . then i turned my attention to what youve
What gave you the bingo! . . . ?
What's that?
To NP the one and only!Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
